Dowloading rates.......
Old Dec 31, 2004 | 03:18 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Dowloading rates.......
Setting aside Torrents, as thats as whole subject of its own to be discussed on my other thread!!
While using Shareaza, which I have used fairly successfully for a while, I am now finding since I changed to 1 Meg and a new PC (running XP SP2) that my download rates are virtually non-existent (10kb at the very best).
I have turned the Windows Firewall off, but it makes no difference. I noticed that there are some other settings that you can apply specifically to the Modem/Router that you are using.
If you go into Control Panel and Click on Windows Firewall, it opens the window that allows you to turn it On or Off. However, if you click Advanced, you can click on the device that you use to connect to the Internet and alter some further settings. Could it be any of these that are pooing up my Download Speeds??
Old Dec 31, 2004 | 04:10 PM
Adrian's Avatar
Adrian
Could just be a shit connection the other end.
Try downloading something from Microsoft as a test.
Old Dec 31, 2004 | 11:15 PM
james_birch's Avatar
james_birch
go to a test site! that will tell ya!
When useing news groups i get my full 2meg worth!
Old Dec 31, 2004 | 11:43 PM
mark_J's Avatar
mark_J
Is this any good, on 1mb
Your download speed : 601880 bps, or 587 kbps.
A 73.4 KB/sec transfer rate.
Your upload speed : 117028 bps, or 114 kbps.
Old Jan 1, 2005 | 02:02 AM
xpackcapri's Avatar
xpackcapri
Old Jan 1, 2005 | 09:10 AM
Stu.H's Avatar
Stu.H
sp2
Old Jan 1, 2005 | 09:56 AM
Smit's Avatar
Smit
The 60ft Launch King
try here
http://bandwidthplace.com/speedtest/index.php
Old Jan 1, 2005 | 10:12 AM
Christian and Beccy
#1 in Spelling Club
Originally Posted by Stu.H
sp2
Thats what the new PC came loaded with. I worry about changing stuff like that because they may not want to help me if I have a problem if I have changed it.
Old Jan 1, 2005 | 11:03 AM
xpackcapri's Avatar
xpackcapri
Old Jan 1, 2005 | 11:24 AM
DanRSturbo's Avatar
DanRSturbo
Best way of testing your download speed is to download something big off microsoft, windows media player 10 for xp is a good test, mine usually stops around 224k a sec
Old Jan 1, 2005 | 07:56 PM
Christian and Beccy
#1 in Spelling Club
What BB are you on?? 1 Meg??
When I am downloading other stuff the download rate is much better, I haven't tried Microsoft, but when I download via Windows, I generally see anywhere between 50-150kb/sec, which I am fairly happy with.
I understand with P2P that is depends on lots of factors (including the type of connection that the other person is on), but you would have thought that the law of averages would occassionally allow you to see a decent download speed, but 25kb really is the best I have seen for a while. I tried using Bit Tornado, just as an experiment and saw 50kb for a little while, but it was more like 35-40kb most of the time.
I get around 900kb/sec by running the Bandwidthplace Speedtest. It says that I can download a 1 meg file in around 9 seconds. Does that sound about right for BT 1 Meg?
Old Jan 1, 2005 | 08:18 PM
Hockney's Avatar
Hockney
C&B with torrents it all depends on how many seeders there are on a torrent. If you have 1 seeder and 50 leechers you will get a shitty d/l speed until alot more people join the swarm or more seeders appear. it also depends on a persons upload rate as well. I'm a member on a couple of BT forums where you can only have uploader status unless you have an upload speed of 10Mb or more so my download speeds always max out at around 480Kbs
Old Jan 1, 2005 | 09:15 PM
stevo's Avatar
stevo
Mate looks like u got half meg not 1 meg connection
Im on 2 meg and get the following
Downstream 2114 Kbps (298.8 KB/sec)
Upstream 251 Kbps (51.1 KB/sec)
Do a test from this site tick the output box
http://www.adslguide.org.uk/tools/speedtest.asp
Old Jan 1, 2005 | 09:40 PM
Ish's Avatar
Ish
Originally Posted by xpackcapri
using that test site i get virtually the same results as i posted except they dont include the overheads so download rate was 120kb/s and upload was 30kb/s. I also have SP2 but have disabled the firewall.
SP2 limits half-open connections (connections waiting for a response from a server) to just 10 to help combat worm spreading. This doesnt help file sharing programs. I have increased mine to 50 by editing the registry but theres a program that does it 4 u, i cant remember the site right now but ill post when i find it.
the registry fix is here http://www.lvllord.de/
Old Jan 1, 2005 | 09:41 PM
S2martin's Avatar
S2martin
Ex Full Price gold member
Downstream 3831 Kbps (478.9 KB/sec) 4137 Kbps (inc. overheads)
Upstream 364 Kbps (45.5 KB/sec) 393 Kbps (inc. overheads)
Is that cool?
Martin
Old Jan 1, 2005 | 09:53 PM
luke89's Avatar
luke89
Team HOTHOT!
should mine be any lower as i have got a router and my bros comp running off it ?? if not then i best get on the phone coz mines way low for 1mb
Old Jan 1, 2005 | 10:50 PM
xpackcapri's Avatar
xpackcapri
Old Jan 1, 2005 | 11:07 PM
luke89's Avatar
luke89
Team HOTHOT!
bro use the comp all the time so thats prob y thanks for clearing that up
Old Jan 1, 2005 | 11:19 PM
Christian and Beccy
#1 in Spelling Club
Is this dangerous in any way before I do it??
Old Jan 1, 2005 | 11:20 PM
xpackcapri's Avatar
xpackcapri
Old Jan 2, 2005 | 01:05 AM
luke89's Avatar
luke89
Team HOTHOT!
wat is sp2 type of conection ??
Old Jan 2, 2005 | 10:20 AM
ESCYSCOTT's Avatar
ESCYSCOTT
bttt for more answers cause i have same problems
Old Jan 2, 2005 | 10:25 AM
Christian and Beccy
#1 in Spelling Club
No, its G A Y Windows XP Service Pack 2. Seems that Microsoft created a revision of XP that EVERYONE hates as EVERY piece of software in the world clashes with it.
Old Jan 2, 2005 | 10:27 AM
james_birch
that and the most stupid hacker could hack xp! so they had to close up alot of loose ends!
Old Jan 2, 2005 | 11:06 AM
Ish's Avatar
Ish
it's working fine on my pc
matts1
Oct 19, 2011 07:21 PM
tregmatt
Jun 20, 2010 09:35 AM
Moondust_crust
Dec 10, 2005 09:28 PM
Toe Knee
Computers, Consoles and I.T.
Nov 10, 2004 08:48 PM
3drSteve
Jan 16, 2004 01:03 AM
