cossie suddenly it started to jerk?!
Was driving the cossie the other day and suddenly it started to jerk, sounded like its low on fuel. Anyway it then sounded like a subaru impreza, that deep engine sound, its hard to explain. Any ideas???? check all plugs, leads etc but not default found.
Right just checked the following, plugs, leads, dissy cap, points and they where fine. However while the engine was running i disconneted the injector one by one and found that cylinder '3' had no impact. The other cylinders were affected but when it came to this one, no response, not doing anything. It must be this right?????
You mean the rotor arm as they do not have points? Have you checked to see if the faulty injector has power by measuring with a meter or by placing a bulb in the connector (sidelight bulb is ideal) you should see a reading of 12V or the bulb will "Pulse" if so this means power is good and injector is faulty.
More than likely it will be a power issue due to the old wiring breaking, remember injectors run 12V CONSTANT not switched.
Martin
Martin
just checked to see if ive got voltage on that injector and thats fine, not reading 12 volts tho, none of them do. Anyway they are all simular so that must be fine. Goner get a single injector i think?!!!!!
If you aren't reading 12volts at any of em, something's up.
Right just checked the voltage on the injectors, all reading around 12.4 volts which is good. Must of put the multimeter on the wrong setting the other day, thats what happens when your in a hurry!!!!!!!!
sridgett
15
03-08-2015 07:26 PM
CabrioTurbo
01-08-2015 11:04 AM
