speedometer needle bouncing?
Old Oct 14, 2009 | 06:50 AM
randomer's Avatar
randomer
rap star!
Default speedometer needle bouncing?
on my escort gti the speedometer needle keeps bouncing after av been driving for awhile..how can i sort this?
Old Oct 15, 2009 | 09:30 AM
You could try taking the cable inner out and greasing it, then wipe away grease, it will still have enough left on it to lube it, they usually do this as the cable gets dry and starts winding up then releasing.
Old Oct 15, 2009 | 09:32 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
thin oil down the cable, bosh
did my bikes the other day, it was bouncing between 140 and 180, :blub:
Old Oct 15, 2009 | 06:25 PM
muffster's Avatar
muffster
i had the same problem with the speedo on my cossie. i took the clocks out and had a look at the mechanism behind the speedo. Had a fiddle around with the worm gear which moves the odometer numbers, and made sure the little cogs were engaging properly, that sorted out a treat.
Muffster.
Old Oct 16, 2009 | 06:34 AM
randomer's Avatar
randomer
rap star!
aww ok cool guys i will give that a try thanx alot
Old Oct 16, 2009 | 06:40 AM
STeve's Avatar
Super Moderator
had this before on my own gti ended up being the drive gear,simple fix though
Old Oct 16, 2009 | 06:47 AM
randomer's Avatar
randomer
rap star!
yea?? how would you fix this?
Old Oct 16, 2009 | 11:20 AM
RichieST's Avatar
RichieST
Happened to a friend of mine on his honda, as above, he ran thin oil down the cable which did sort it, however about a year later it started doing it again, so he bunged a new cable on, and its been fine for the last 4 years!
Old Oct 16, 2009 | 11:33 AM
randomer's Avatar
randomer
rap star!
aww i love this place..solves everything lol
al give that a try guys thanx if it happens again al just hange the cable
Old Oct 16, 2009 | 09:16 PM
RSsandybeaver's Avatar
RSsandybeaver
Question Mines worse
So why does my speedo read "20 MPH" below what the car is doing
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Tinshaw
Aug 4, 2015 09:16 PM
Sticky.
Jan 7, 2005 09:45 PM
Ford Focus RS
11
Jan 22, 2004 09:36 PM
