Central heating/boiler problem!!, Help!
Old Jul 29, 2009 | 10:19 PM
Neil Clark's Avatar
Neil Clark
Default Central heating/boiler problem!!, Help!
Right, odd one this!
Its a worcester combi-boiler.
The little gauge that tells you the pressure of the rads keeps going up past 4bar (should normally be 1-2bar) so you have to drain about a litre out the rads. This happens over about 3-4 days. Its only been doing it the past week or 2.
The pipe to connect the boiler to the water supply is disconnected all the time so cant be going in there!
Any plumbers on here!!??
Old Jul 29, 2009 | 10:26 PM
escossie's Avatar
escossie
Sounds like its the hot water heat exchanger passing between the mains water & primary water so chances are you need a new heat exchanger. Which worcester combi is it?
Old Jul 29, 2009 | 10:28 PM
TIFF's Avatar
TIFF
Chasing Radders
Well if there is no water going into the system............there is 2 outcomes.
1-The gauge is fucked
Or
2-The water is finding its way into the heating system via the hot water side....which i am not 100% sure it can as they are 2 seperate systems.
I would test the gauge first......or even fit a auxillery one on the flow pipe. That way you will see the pressure iin the heating system.
If you dont release the pressure, does it fire the Blow off valve and empty itself???
Old Jul 29, 2009 | 10:32 PM
TIFF's Avatar
TIFF
Chasing Radders
Could possible need the expansion vessel re-charging as this can sometimes make the pressure creep up.........
The red expansion vessel has a valve on it that you connect a foot pump/bike pump to. Make sure it is reading 1.5 bar.........if it isnt, pump it up to this pressure. That may fix the issue
Old Jul 29, 2009 | 10:36 PM
Neil Clark's Avatar
Neil Clark
Not 100% sure, quite a big one tho (12 rads i think)
Will get model number tmrw
Old Jul 29, 2009 | 10:37 PM
Neil Clark's Avatar
Neil Clark
Thats for help, i've read that 3 times and my tiny mind cant make sense of it lol
Old Jul 29, 2009 | 10:38 PM
ryan81's Avatar
ryan81
is the filling loop disconected or jsut in the isolate posistion ?
if its completely disconnected it`s the heat exchanger, if its in the isolate pos it could be by passing
Old Jul 29, 2009 | 10:39 PM
Neil Clark's Avatar
Neil Clark
Completly removed mate
Old Jul 29, 2009 | 10:40 PM
TIFF's Avatar
TIFF
Chasing Radders
I will try and make it easier for you Neil.......lol
If you turn the boiler off, then remove the front cover.....usually a few screws.........
You will see a red vessel at the back i think it is......this is the expension vessel.
On it will be like a tyre valve that you use to blow the tyre up with. Stick a pump or gauge on it and see what it is reading. It should be 1.5bar........
If it isnt, pump it up to that
Old Jul 29, 2009 | 10:42 PM
Neil Clark's Avatar
Neil Clark
LOL, thats better mate, remember i'm thick!
I'm not taking the covers off mate, i will almost certainly kill myself!
Old Jul 29, 2009 | 10:43 PM
TIFF's Avatar
TIFF
Chasing Radders
Neil.....if you turn the fuse spur off to it you will be fine.........
Old Jul 29, 2009 | 10:45 PM
Neil Clark's Avatar
Neil Clark
Its on a plug mate so all good
I havnt got owt to check pressure anyway, best ring a plumber tmrw..... more money down the drain!
Old Jul 29, 2009 | 10:46 PM
ryan81's Avatar
ryan81
well if it`s removed , i would say its your HX (heat exchanger ) at fault , an hours labour + part
Old Jul 29, 2009 | 11:46 PM
Fewkesy's Avatar
Fewkesy
AS above mate.
will be your plate heat exchanged pinholed internally. could only be a vessel fault if you have been running your heating but i doubt it at the moment.
this is becoming quite common at the moment due to sludge build up in the system. a good product to add while your changing it is a magnaclean. They are brilliant and will help stop it happenning again.
hope this helps
Old Jul 30, 2009 | 05:49 AM
Neil Clark's Avatar
Neil Clark
Originally Posted by Fewkesy
AS above mate.
hope this helps
Not a plumber are you? i'm only in Derby!
Old Jul 30, 2009 | 06:15 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
try ringing their technical helpline bud 08705266241
its 24hr
always been helpfull to me
Old Jul 30, 2009 | 08:27 AM
RSTurboSI's Avatar
RSTurboSI
give exitpoint a Pm..but best if you call him heres his contact page.
http://www.plumbromany.co.uk/
hes in nottingham, and use me as a referance. Simon colton.
hes a real good mate. so will make sure you are sorted.
Old Jul 30, 2009 | 09:45 AM
TIFF's Avatar
TIFF
Chasing Radders
hope this helps
I always fit these now.....superb product
Old Jul 31, 2009 | 12:01 AM
Fewkesy's Avatar
Fewkesy
Thumbs up
yea i am mate. i work for british gas on the breakdown side.
if you struggle to get some1 then let me know.
Old Jul 31, 2009 | 06:15 AM
Neil Clark's Avatar
Neil Clark
Cheers all!
Got worcester coming on Monday, one off payment off Ł210 and will fix any problem (they say!)
Old Jul 31, 2009 | 04:29 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Have you got very high mains water pressure?
Old Jul 31, 2009 | 09:56 PM
Neil Clark's Avatar
Neil Clark
Dont think so, just normal i think
Old Aug 1, 2009 | 10:35 AM
Jon(M600BHP)'s Avatar
Jon(M600BHP)
More than likely the little pipe feeding the expansion vessel is blocked or as said above the vessel has lost its charge, So just needs draining down and expansion vessel pipe removing and cleaning and vessel pressure checking But deffo get an engineer to do it thx Jon
Old Aug 1, 2009 | 10:56 AM
TIFF's Avatar
TIFF
Chasing Radders
Funnily enough Neil....i had a call out yesterday for the exact same thing as yours......And like i said in my earlier post, It was the expension vessel needed recharging....
I charged them Ł50..............
Old Aug 1, 2009 | 03:57 PM
Neil Clark's Avatar
Neil Clark
Come as far as Derby for work mate?
Old Aug 2, 2009 | 05:37 PM
TIFF's Avatar
TIFF
Chasing Radders
lol...........if i was closer i would mate.......
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
