Seized sunroof
It could be that the rubber seal is stuck to the roof, you could try spraying it with WD40 and banging it to free it up, if it's the mechanism you'll have to remove the roof lining I guess
Best way is to use a plastic ruler lots of soapy water around edge, and prise the plastic ruler between the two all the way around, this frees the seal, now go around the edge again applying pressure to loosen a bit more, then try handle apply a bit of pressure and thump the sunroof, it will come loose, but does need patience, as otherwise the mechanism can break.
Our Saff has a seized sunroof, have tried to free it off, ended up stripping the mech and now its totally foooked. Iam not quite sure how you can remove the whole mech if you carnt open the sunroof.
