For You RS XR ST Ford Daily Drivers.
Hunka Hunka Burning Love
So what has your unreliable fast ford cost you this year for parts that have broke etc? (not including servicing,)
I will start.
Alternator and 2 belts, not bad including its used every day..
I will start.
since i bought mine in feb - S2 RST
full engine rebuild as it lasted 6 weeks
2 tyres
ABS pipe split
2 wheel bearings
headlight failure ( stil not fixed )
radiator
alternater
and since the engine went in march it was off the road for 3 months, so not good really
2 tyres
ABS pipe split
2 wheel bearings
radiator
alternater
sideways all the way!
prop
diff
driveshafts
thrust bearing
clutch cable
2 new tyres
3oil changes
3door actuators
abs tank
exhaust welded
and its only done 1500 miles
and its mot in 2weeks
diff
driveshafts
thrust bearing
clutch cable
2 new tyres
3oil changes
3door actuators
abs tank
exhaust welded
Lucifer II - 666
Diff
Manifld
Rear Bumper as of today
Manifld
4 new tyers £ 300
steering rack £25
rear shocks £115 each
ignition leads £40
spark plugs
wheel bearing £50
steering wheel bush £20
escort rst s2 loads ov other stuff to but not repair work
steering rack £25
ignition leads £40
spark plugs
wheel bearing £50
borboyous
22-08-2015 11:17 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
