knock sensor and lambda wiring L8 MSD peeps?
Old May 24, 2009 | 06:15 PM
Paul_RS's Avatar
Paul_RS
Default knock sensor and lambda wiring L8 MSD peeps?
In preparation for fitting an L8, i thought i'd have a look at the ECU wiring on my super 8.
Had a poke around and barring the extra injector/boost pot looms that will need to be reomved from the connector, i found 3 wires disconnected.
They are
Brown White
Blue Brown
Blue Green
I had a look at a wiring diagram and they seem to be
Pin 2 on the ecu - Brown White - Lambda sensor
Pin 6 on the ecu - Blue Brown - Knock Sensor
Pin 22 on the ecu - Blue Green - Knock sensor
I take it when i fit my L8 (going closed loop/wasted spark) i can just plug all these pins back in where they should be with no issues?
My car is '91 and never had a lambda fitted, so i assume this along with the knock sensor wiring was removed for ease of fitment of the second 4 injector wiring?
Would just like someone to confirm what i'm doing is correct
Old May 24, 2009 | 10:43 PM
Paul_RS's Avatar
Paul_RS
Anyone?
Old May 24, 2009 | 10:48 PM
DAN400's Avatar
DAN400
what happened with the dta ?
Old May 24, 2009 | 11:03 PM
Paul_RS's Avatar
Paul_RS
Couldn't be arsed
Nah, i've decided not to do the engine this winter, so i don't need DTA yet.
Just want something plug and play for now. An L8 with the wasted spark driver in it came up at a very good price, so i thought i'd fire that in for the mean time
Old May 25, 2009 | 06:12 AM
Stu @ M Developments's Avatar
PassionFords Creator
Correct, they should just be reconnectd and all will be well but bear in mind the lambda may be dead if its been unpowered for any length of time.
Old May 25, 2009 | 02:10 PM
Paul_RS's Avatar
Paul_RS
Cheers Stu!
My car is a non cat model, so its never had a lambda fitted, but it has the wiring. Bought one of your Bosch ones from Will when i ordered the rest of the kit
Wonder how long standard diffs will last with launch control
Old May 25, 2009 | 02:25 PM
KSA-Cossie's Avatar
KSA-Cossie
Know the feeling m8.
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
RSmark84
Sep 13, 2015 01:29 PM
Si B
Sep 12, 2015 06:49 AM
