What plugs for a 2.1 16v Zetec turbo??
Old 07-12-2004, 11:25 PM
Rossco
Rossco's Avatar
Default What plugs for a 2.1 16v Zetec turbo??
Right iam curently having a Zetec turbo built, iam aiming to run 15-20psi, what plugs should i use, ive seen a few people have the head drilled and tapped to use Champion C59`s.
Your thoughts please.
Thanks Ross.
Old 08-12-2004, 06:45 AM
PhilM
PassionBMW.com Member
PhilM's Avatar
Can drill and tap for cossie pl;ugs, if you do that id use NGK 9s.
I kept the std plugsize and use Focus RS items.
Old 08-12-2004, 07:33 AM
B19-TRB
B19-TRB's Avatar
machine the head & run NGK 9's!
I ran C59's & they lasted about 800miles!
9's r still gooin strong i believe @ over 3000miles
Old 08-12-2004, 08:02 AM
Garage19
Garage19's Avatar
Not sure if you have to drill AND tap the head for cossie threads. I thought you just had to machine the head so that the spark plug thread is shorter for the cossie plugs? I may be wrong on this one
Any way, I totally forgot about that when I built my engine so shall be running focus RS plugs along with PhilM!
Anyone found anywhere cheaper than Ł28 a set fo these?
Cheers,
DC
Old 08-12-2004, 08:05 AM
B19-TRB
B19-TRB's Avatar
Ł28 is cheap m8!
NGK 9's r Ł100
Old 08-12-2004, 08:06 AM
PhilM
PhilM's Avatar
Garage, your quiet correct, the head just needs machining, not drilling, oops, far too early! Fords were about Ł20 for mine!
Old 08-12-2004, 08:20 AM
Garage19
Garage19's Avatar
Glad i didn't machine the head then! Tight as a ducks arse, me!
Hows it going Phil? Run her up yet?
Gonna do my Septic Peg trick and say.... you are worring about the bodywork of your car.........you feel you need a new bonnet.....!
Old 08-12-2004, 09:08 AM
Rossco
Rossco's Avatar
Cheers guys
Garage19 you have PM mate.
Old 08-12-2004, 03:06 PM
PhilM
PhilM's Avatar
LOL, Tillio should learn to keep his mouth shut
Took her for a brief spin yesturday, having not driven ehr yet (Simon @ SECS did the week before), Ive sorted the brakes so they work now .....however still gunna be ripping out the lot and redoing it all so they are spot on, but they work....so thats fine for now
Also, been working today in the hanger on my throttle body, had a problem that idle was high, no airleaks we could see, but, it turned out the throttle wasnt closing fully, so sorted that now, refit at the weekend I guess All I need now is a jubiee clip for my airfilter lol as the one it came with keeps ripping open!.
Hows yours bud?
Old 08-12-2004, 06:14 PM
david
david's Avatar
Is it worth getting the head done to accept other plugs or will the st170 one's do the job ??
Old 08-12-2004, 11:13 PM
Rossco
Rossco's Avatar
Old 09-12-2004, 06:54 AM
PhilM
PhilM's Avatar
I was taking the piss out of something Doug said mate
Old 09-12-2004, 06:38 PM
Garage19
Garage19's Avatar
I used to go to school with old Mr Till. Popped round his to pick up a couple of bits and noticed your name written in white board pen on the bonnet of an RST he was breaking!
Small world, eh!
Does this mean you have had your mapping done? Or are you just running her on a base map?
I'm just trying to get my inlet manifold to fit under the bonnet at the mo, so not quite up and running yet.
I have been looking at a new bit if kit to help me with my mapping though!
http://www.zeitronix.com/
Its a wide band o2 sensor/read out package with a nice LCD display and data logging facilities.
With the current exchange rate it works out at 207 quid. Bargain I thought!
Old 09-12-2004, 06:45 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
That wasnt a car he wa sbreaking it was phil's
Old 10-12-2004, 08:04 AM
PhilM
PhilM's Avatar
Div, stop sh*t stiring and go learn to drive
Doug, sweet . Just a base map for the moment until I fit the new brakes I just received (also from Mr Tillio ). Looks very good that mate if you want a display! I will be purchasing one of these though when I get chance tyo (next student loan isnatllment lol).
http://www.innovatemotorsports.com/x...cat=248&page=1
Very good peice of kit, similar price!, no display though, but I will probably be making my own anyway to talk to a few things, ECU Data, GPS data etc. Maybe even a new secs monitor when they are out
JoeyBoyden
04-01-2024 02:36 PM
robnock
21
13-05-2019 05:29 PM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: What plugs for a 2.1 16v Zetec turbo??
