Zetec Vs Duratec Turbos?
PF's Guitar God!!!
Hi guys
Just a question about engines. Just trying to get knowledge on both.
Which would make a better Turbo engine out of the Duratec and Zetec for a RWD Focus MK1, and why?
Cheers Folks
Cheers Folks
i'd say the zetec just because they're more available and there are more aftermarket parts available for them, and there seems to be a lot of information about for turboing a zetec, duratecs are still reletively new
PF's Guitar God!!!
well i plan to learn about driving on track. My mate suggested a WRC CGI Zetec Block. I'm willing to spend the money and i admit it may take a little bit of time to get in order as i will have to prep the Focus exterior and have it resprayed.
To make it Rear wheel drive what would need to be done?
PF's Guitar God!!!
well it all boils down to budget, i'm no expert but if you have the money then a duratec is the way to go but if not you can get good power out of a zetec for a lot less, the weight difference only makes a big difference if its in someting like a kit car
PF's Guitar God!!!
Yeah i guess the budget will be enough for a Zetec.
hi mate zetec turbo the way to go as you can see 500/600bhp with 2bar of boost
and will stay reiable as well. as far as i know ian howell of area six motorsport is the only person to try and turbo the duratec engine and try and get massive power figures and he spent a fortune on the head, turbo, inlet, sump, pistons, rods and in the end it was the block that was the weak point . it made a good 450bhp at 1 bar but split the corner of the block off and i mean split a whole section of metal off the corner. after spending all that money £20,000 he looking into getting a mazda modified thickwalled block from the usa but at a cost of nearly £5000 he gave up and called it a day.
hope this helps mate
cheers paul
cheers paul
cheers paul
cheers paul
Mazda over here run turbocharged duratecs.
cheers paul
cheers paul
Wasn't the engine machined for liners?
Not the point of how much power, these engines will have been pushed to destruction and beyond before they even thought about using it in production cars.
yes it was mate but with the increase in water temps it just split the block. the block wall that he showed me was only about 5/6mm thick compared to the zetec cast iron block which is alot thicker
also can you show me a dyno provern 500+bhp duratec 2.0l or 2.3l i dont think i have ever seen one but correct me if iam wrong
its not about who got the most power ,its about reiablity and the zetec engine has provern its self on more than one ocassion
thats just my opinion mate
cheers paul
That's the problem with a lot of engines now - alloy blocks are no good for very high cylinder pressures used in forced induction.
Was this engine that Ian played with the one that was posted in the restoration section? I did wonder what happened, fair play - thats a lot of money to spend developing!
Rick
I'm talking N/A, they can shift serious amounts of air.
Rick
Rick
paul
PF's Guitar God!!!
True. But if i remember Ian Howells first Focus, he had a WRC CGI Block running 370bhp. I guess it just adds to peace of mind that there alot more the block can handle.
I'm still working out calculations for this project and if it exceeds 15K i rather buy something thats already quick. If not i'll have to give into Sineads argument and buy a family motor. hmmmm RRS TDV8 lol
PF's Guitar God!!!
i am not 100% sure about the carbon block mate as this engine went into paul johnson fiesta and he is now using it in the focus i think its a zetec silvertop bottom end. ian said not to use the zetec cgi block as i was going to buy one off him as he had 4 for sale as they need alot of modding to them fit a road car , everything has to be custom built and he said its not worth it. my engine did 522bhp on a standard silver top engine and the best bit is i think hes selling the same engine package for £10,500 including pectel t2 ecu so you can take your missus on holiday aswell and he gives 12 months warranty , bargain
Its still a project idea that i'm playing with. Sinead is on my case as she wants to have a child of our own, and she already has 2 of her own. As much as i really want to go through with this project, i think sinead will put a stop to it. + she knows her cars and i don't think she'd appreciate 15k spent on a Ford
Focus St mk2 310 bhp :D
Not too sure on all the duratec hate in this thread
If you want less than 500bhp i'd go for the duratec if you want over you WILL NEED a zetec mate
But what kind of power are you going for?
i dont hate anything mate well done for being different and having the bollocks to do it but the thread was about which engine was best to tune and at the minute i would have to say the zetec as it has a provern track record of big power
Nah mate you've got me wrong i'm not having a go at you or anything but thread isn't about whats the best to tune it's about which would be better for this given application, which is why I asked how much bhp he wants
As if it's under the 450-500 bhp mark surely the duratec would be better as it'd same him weight on his track car?
300 is piss easy on a Duratec, which IMO is far superior to zetec.
Having recently witnessed a marathon testing session with different ecu's on the same car/s(there were three cars, all slightly different engine spec), all trying different sized tb's, it was clear to see how easy it was to crack 300bhp with excellent torque as well, but christ were they noisy.
Matt Baxter
16-09-2015 08:30 PM
