well ive bought the inlet and ordered the gt35r :)
Old 13-09-2008, 06:39 PM
  #81
rapidcossie
rapidcossie's Avatar
from testing on my car one 044 is not enough for 550 bhp.
Old 13-09-2008, 06:46 PM
  #82
stevieturbo
C**t
stevieturbo's Avatar
What size feed/return and injectors ?
Was fuel pressure dropping on yours with just one ?
Old 13-09-2008, 06:50 PM
  #83
Mark Shead
Mark Shead's Avatar
Originally Posted by spaceview
they surge badly when trying to run high boost at the bottom so you have to limit it they also dont make quite as much bhp at the top but there is many factors that could have affected this so could be very much differernt on your engine due to the spec
Its not the GT35 that causes surge its the tuner.
Mark
Old 14-09-2008, 12:30 PM
  #84
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Mark
Old 14-09-2008, 12:34 PM
  #85
J1mbo
B1mbo
J1mbo's Avatar
Mark
they are talking about a internal gated gt35 which iirc was worse that a external wastegate gt35 ?!
Old 14-09-2008, 12:37 PM
  #86
Mark Shead
Mark Shead's Avatar
No its not, I have used bothfor sure the exhaust housing doesnt flow as well as the external, But its not that thats causes surge.
Mark
  #87
J1mbo
B1mbo
J1mbo's Avatar
Mark
ahh right
Old 14-09-2008, 12:59 PM
  #88
scoooby slayer
scoooby slayer's Avatar
afaik surge is when the engine cant consume the air nothing to do with wastegate. but to small a wastegate can cause boost creep as gas cant bypass turbine quick enough. thats how i understand it anyway.
Old 14-09-2008, 07:30 PM
  #89
scoooby slayer
just ordered genuine wrc headgasket and ford standard bolts
Old 15-09-2008, 05:36 PM
  #90
Staffi
Staffi's Avatar
What box & diff have/are you using fella??
Old 15-09-2008, 05:40 PM
  #91
Mark Shead
Mark Shead's Avatar
Do check the head bolts are proper ford ones, They will have KXA1000 4wd and KX1000 2wd.
Mark
Old 15-09-2008, 06:38 PM
  #92
J1mbo
B1mbo
J1mbo's Avatar
dont you have a longstudded block ?
Old 15-09-2008, 08:04 PM
  #93
Roosie
500bhp Cosworth in making
Roosie's Avatar
please dont brinh that debate up
Old 15-09-2008, 08:09 PM
  #94
J1mbo
B1mbo
J1mbo's Avatar
lol its a vadil point tho
Old 15-09-2008, 08:14 PM
  #95
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Mark does not own a YB so I guess thats a NO.
Old 15-09-2008, 08:25 PM
  #96
J1mbo
B1mbo
J1mbo's Avatar
was i talking to mark ? lol i mean scooby slayer rod
Old 15-09-2008, 10:08 PM
  #97
scoooby slayer
no mate nms way mate wrc and standard bolts. thats what i bin running and i havnt broke it yet.
Old 15-09-2008, 10:10 PM
  #98
scoooby slayer
Mark
thanks mark il check on that. getting from woodford and he said genuine so should be ok. ive ordered late type bolts as thats what its got in it but its got 2wd head ? should it be early bolts for 2wd and late type for 4x4 head ?
Old 16-09-2008, 06:14 AM
  #99
CossieRich
CossieRich's Avatar
Careful from Woodford. I ordered standard stretch bolts and before i put them in, Mark said let me see those. Turned out they werent proper stretch bolts and didn't have the correct code number as Mark stated above. Luckily he had some in stock
Old 16-09-2008, 06:43 AM
  #100
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Thing is they are not too expensive from a Ford dealer, at least you would get the genuine thing from there too.
Old 16-09-2008, 07:16 AM
  #101
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Sorry Jimbo, my attempt at humour failed .
Old 16-09-2008, 12:25 PM
  #102
scoooby slayer
il have to check them when they get here. the reason i went to woodford is have receipts from previous owner from woodford for engine thats in the car totalling 3k for block, gaskets etc. and has been a good engine no failures and some hard abuse.
Old 17-09-2008, 11:21 AM
  #103
scoooby slayer
well inlet is good just needs a lug alloy welding on for mounting bolt. and turbo should be here tmrw
Old 17-09-2008, 11:32 AM
  #104
scoooby slayer
headbolts are here cant see any part number on them ? should they be threaded almost right to the head bar an inch ? and headgasket is here part no 24RNZ07 -311110-00 is that right for genuine wrc ?
Old 17-09-2008, 04:21 PM
  #105
Mark Shead
Mark Shead's Avatar
The part number is around the top ring of the bolt where you put the tool in to.
Mark
155lee
27-10-2015 04:55 AM
Eigdoog
48
19-09-2015 11:03 AM
Chopshop85
12-09-2015 06:42 PM
Si B
12-09-2015 06:49 AM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
Quick Reply: well ive bought the inlet and ordered the gt35r :)
