Closed loop Co prob
Old Jul 26, 2008 | 01:58 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Default Closed loop Co prob
Just fitted a msd closed loop chip
Took the car into work to check the co and this is what i have
Wtf is going on
Could this be a sensor problem i used a bosch lambda sensor(not from msd) so should i try another lambda
This is all new stuff to me
Old Jul 26, 2008 | 01:59 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Did you follow the procedure for resetting the CO screw aswell that came with the fitting instructions for the chip?
Old Jul 26, 2008 | 02:04 PM
Matt Baxter
Back in black!
yeah did all that
Old Jul 26, 2008 | 02:06 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
put a multimeter across ecu pins 1 and 2....you should see the rise and fall in voltage from the lambda sensor....
all base settings correct? ie fuel pressure
Old Jul 26, 2008 | 02:09 PM
JTECH James
Passion for Fords!
you did the wiring change on your tps? if it was L6....before
Old Jul 26, 2008 | 02:16 PM
Matt Baxter
Back in black!
fuel pressure set to 3 bar
just checked wih the multimeter set to 20v and was getting a reading of .065 ish
and got a 2nd hand 4x4 tps off Ryan and swapped the wires over this morning
Old Jul 26, 2008 | 02:28 PM
JTECH James
Passion for Fords!
fuel pressure on stus chips is 3.5bar at idle, vac pipe off...giving around 3.2 pipe on.
how did you set the tps up?
how old is your ect sensor?
Old Jul 26, 2008 | 02:38 PM
Matt Baxter
Back in black!
ect is less than 2 years old
set the tps to .35v via pin 1 and 17
the engine has always had high co but this takes the piss
Old Jul 26, 2008 | 02:43 PM
JTECH James
Passion for Fords!
try unplugging the lambda ..does the c.o change?
you deffo have a sensor fault of some sort,
lambda, ect, map sensors would be the more likely
you got a secs monitor?
Old Jul 26, 2008 | 02:51 PM
Matt Baxter
Back in black!
got a secs moniter the map sensor part has never worked (thinking about it always shown 0.00)
Old Jul 26, 2008 | 02:53 PM
Matt Baxter
Back in black!
back home so cant see if the co changes but i have a zeitronix afr if i could use that
Old Jul 26, 2008 | 02:55 PM
Jim Galbally's Avatar
Jim Galbally
lamda wouldnt cause the mixture to be out by THAT much tho! i suspect a more important sensor fault
Old Jul 26, 2008 | 02:56 PM
JTECH James
Passion for Fords!
check your secs wiring then for the map signal....you may find its over reading...
the white wire on your secs loom, goes to pin 15 on the ecu plug
Old Jul 26, 2008 | 03:00 PM
JTECH James
Passion for Fords!
they can do jim, mine went to 8%odd when the lambda was unplugged, it depends how the global mod is adjusted iirc.
they always go rich when lambda sensor fails for safety
Matt Baxter
Back in black!
its got a new loom off Ryan but was the same this with the old loom
Old Jul 26, 2008 | 03:02 PM
Matt Baxter
Back in black!
think i will get a new map sensor and see what that does anything
Old Jul 26, 2008 | 03:04 PM
Jim Galbally
jtech, not THAT rich tho
the closed loop wouldnt even adjust that much extra fuel if it was reading constantly lean on the sensor!
Old Jul 26, 2008 | 03:06 PM
JTECH James
Passion for Fords!
mine did jim,,,it ran at 0.90% LS plugged in, and 8%unplugged
on 55lb injectors.
i could weaken it off,by using the global mod, but i ran it uber safe at the top, so chose to run it rich, the closed loop dealt with it a treat low down
mind you i probably had big issues back then
Old Jul 26, 2008 | 03:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Best to phone stu and make use of his excellent after sales service matt.
Old Jul 26, 2008 | 03:58 PM
Jim Galbally
i don't beleive for a minute that stu sets his base map to 8% and the closed loop is the only thing bringing it down to lambda 1.
there must be something fishy going on
Old Jul 26, 2008 | 04:16 PM
JTECH James
Passion for Fords!
it was a year ago
its all new now
Old Jul 26, 2008 | 05:21 PM
Matt Baxter
Back in black!
i tried to call him but the lazy git only does a half day on saturdays
with any luck stu will see this post and might be able to shed some light on whats going on
Old Jul 26, 2008 | 05:24 PM
JTECH James
Passion for Fords!
hes playing metal gear solid on his ps3 right now
Old Jul 26, 2008 | 05:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Alright for some. !!
Old Jul 26, 2008 | 07:44 PM
Matt Baxter
Back in black!
i know, i must be doing the wrong job
Old Jul 26, 2008 | 08:00 PM
Tev's Avatar
Tev
not sure if its any help bu twhen i had my car set up at stus kenny couldnt get the ecu to lock on to the lamber sensor, it kept returning to base map, turned out the lamber was fooked
Old Jul 26, 2008 | 08:14 PM
trevCOSS's Avatar
trevCOSS
Stalker
Matt I assume the car is warm etc whenyour checking the co? does it idle very smoothly or seem to slightly hunt?
Old Jul 26, 2008 | 08:25 PM
Jim Galbally
tev, it shouldnt be 8% when its stone cold
Old Jul 26, 2008 | 08:29 PM
Matt Baxter
Back in black!
Originally Posted by trevCOSS
Stalker
yeah nice and hot fans had cut in/out
the idle is fine/smooth (idle valve disconnected)
Old Jul 26, 2008 | 08:31 PM
Tev's Avatar
Tev
rubbish im all out of ideas then lol
Old Jul 26, 2008 | 08:34 PM
Stu @ M Developments's Avatar
PassionFords Creator
Evening Matt, before i go back to MGS, have you actually tried triming it with the CO screw? Some of the ECU analogeis circuits seem to differ. try taking 1 - 2 turns anti clockwise off the trimmer.
failing that, i would be looking at ECT/ACT/LAMBDA.
Old Jul 26, 2008 | 08:56 PM
Matt Baxter
Back in black!
Hi Stu
yeah tried adjusting the co screw didnt make a lot of difference (was at 9+ co)
can you do me a deal on all of the above sensors + map sensor as at least then i can rule them out
Old Jul 26, 2008 | 08:58 PM
Matt Baxter
Back in black!
also on the afr its about 10.5 at idle what sort of figure should be looking for
Old Jul 26, 2008 | 08:59 PM
boost mad's Avatar
boost mad
did you get the lambda just for this ? or for a wideband gauge ?
if you got it for wideband gauge have you defo got the simulated narrowband going to the ecu ?
as i belive the ecu closed loop runs off a narrow band signal
just a thought
Old Jul 26, 2008 | 09:03 PM
JTECH James
Passion for Fords!
14.5-14.7 ish id say
Old Jul 26, 2008 | 09:39 PM
Jim Galbally
it should be bang on 14.7 as it's closed loop
10.5:1 would be considered "properly rich" even if on full boost at full revs
Old Jul 26, 2008 | 09:42 PM
Neil S's Avatar
Neil S
Jim it will cycle as it's in a closed-loop feedback system
e.g.
Lambda < 1: Trim fuel
Lambda > 1: Add fuel
ad nauseum.
Neil.
Old Jul 26, 2008 | 09:44 PM
Jay,'s Avatar
Jay,
Sponsor
pmsl @atu playing ps3 that shit will stop when young un makes a appearence
Old Jul 26, 2008 | 09:46 PM
JTECH James
Passion for Fords!
doesnt stay static jim
take it you have seen a lambda signal on a scope then......
Old Jul 26, 2008 | 09:47 PM
Jim Galbally
yeah but it will wander around 14.7 not 14.5
