Closed loop Co prob
Old Jul 26, 2008 | 09:48 PM
  #41
Jay,'s Avatar
Jay,
Sponsor
i take the co pot works matt?
Old Jul 26, 2008 | 09:51 PM
  #42
Matt Baxter's Avatar
Matt Baxter
Back in black!
yeah i adjusted the screw and it made a little bit of differance
The engine has always been a bit high but this takes the piss
Old Jul 26, 2008 | 09:53 PM
  #43
JTECH James's Avatar
JTECH James
Passion for Fords!
Originally Posted by Jim Galbally
yeah but it will wander around 14.7 not 14.5
yes they do..
14.5, 14.7, 14.9 ish
Old Jul 26, 2008 | 09:54 PM
  #44
trevCOSS's Avatar
trevCOSS
Originally Posted by JTECHSAFF
yes they do..
agreed float about around those figures
Old Jul 26, 2008 | 10:02 PM
  #45
Jay,'s Avatar
Jay,
Sponsor
im not convinced its lamba related its just to high re do the tps and change the water air temp for the sake on 20 quid itll be worth it
Old Jul 26, 2008 | 10:04 PM
  #46
Jay,'s Avatar
Jay,
Sponsor
tell u what ill give u a ring in the morn i might have a new sensor set in the avalanche as i changed it all to run the dta if so there urs
  #47
Mark Shead's Avatar
Mark Shead
Wheres the coil lead/coil pack in relation to the mapsensor.
Mark
Old Jul 26, 2008 | 10:05 PM
  #48
Jay,'s Avatar
Jay,
Sponsor
Mark
ah bloody good point
Old Jul 26, 2008 | 10:06 PM
  #49
Matt Baxter
Back in black!
Mark
coil pack is up by the heater motor the map sensor is still on the ns inner wing
Old Jul 26, 2008 | 10:08 PM
  #50
Jay,'s Avatar
Jay,
Sponsor
and does the lamba lead go any where near the coil and is it shielded ?
Old Jul 26, 2008 | 10:11 PM
  #51
JTECH James
Passion for Fords!
surely if the act, or ect were far enough out to raise the co this much you could spot an unrealistic value on the secs monitor?
Old Jul 26, 2008 | 10:12 PM
  #52
Matt Baxter
Back in black!
no not shielded but its not close to the coil/leeds either(5-6"away)
Old Jul 26, 2008 | 10:23 PM
  #53
Jay,'s Avatar
Jay,
Sponsor
how close to ignition leads ect as it will effect with interference matt
Old Jul 26, 2008 | 10:28 PM
  #54
Matt Baxter
Back in black!
lambda wiring is about 6" away from coil pack and leeds
Old Jul 26, 2008 | 10:39 PM
  #55
Jay,'s Avatar
Jay,
Sponsor
no to give you a example my fuel pressure gauge sender was 8 inch away from a coil lead and was giving a reading of 70 psi when actual reading was 45 psi , the coil and leads give off quite a strong interference signal which in turn give wrong readings or conflict readings
Old Jul 26, 2008 | 10:43 PM
  #56
Jay,'s Avatar
Jay,
Sponsor
true but is it seeing the right value or is it working correctly
the act or ect will have a default setting that will put the car rich if they are not connected properly or broken so the car will be rich what ever happens
Old Jul 26, 2008 | 10:50 PM
  #57
JTECH James
Passion for Fords!
likewise the map sensor value cannot be seen on his secs, and the fact its in the std place under the header tank, where they get wet...id deffo check that out....they dont like moisture up em
could be fuelling for 30psi at idle
Old Jul 26, 2008 | 10:53 PM
  #58
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Jim "the oracle" galbally. When will you learn to stfu!?
Old Jul 26, 2008 | 10:55 PM
  #59
Jay,'s Avatar
Jay,
Sponsor
best fit agressive anti lag then
Old Jul 26, 2008 | 10:56 PM
  #60
Jay,'s Avatar
Jay,
Sponsor
jims a I.T geek im suprised he hasnt said turn it off from the mains wait 30 seconds and reboot
Old Jul 26, 2008 | 11:26 PM
  #61
BRIGSPORT's Avatar
BRIGSPORT
I really don't know where he gets it from. He's gone from such classic posts (on interford) as coz we're boostin and a brakin!, to reckoning he's a world leader in closed loop,and religious factions in the western world!
Old Jul 27, 2008 | 08:00 AM
  #62
foreigneRS's Avatar
foreigneRS
Testing the future
have you got a leaky injector? perhaps try unplugging them 1 by 1
Old Jul 27, 2008 | 09:18 AM
  #63
Matt Baxter
Back in black!
the injectors are less than a year old also i would of thought it wouldnt tick over as smooth as it does
But its worth a look
edit
thinking about it the co was quite high befor the new injectors were fitted
so it must be a sensor
the last few mot's we did i had to turn the fuel pressure down to about 1.5 bar
Old Jul 27, 2008 | 09:28 AM
  #64
yrkesman's Avatar
yrkesman
just checked wih the multimeter set to 20v and was getting a reading of .065 ish
If your lambda voltage is 0.065V then there is something wrong.
http://www.siipicossu.com/O2-Sensor.gif
Old Jul 27, 2008 | 10:19 AM
  #65
JTECH James
Passion for Fords!
go to be some sensor fault somewhere
Old Aug 16, 2008 | 08:30 AM
  #66
sygjim's Avatar
sygjim
some news ?
Old Aug 16, 2008 | 08:52 AM
  #67
Ridgey's Avatar
Ridgey
Had my idle CO checked yesterday after fitting L8 closed loop and without any adjustment it was reading 0.55%
Old Aug 16, 2008 | 10:39 AM
  #68
JamesH's Avatar
JamesH
If you unplug an injector the CO will increase because of mifire.
All th problems many seem to have with the closed loop setup really makes me wonder if it is the way to go or not!!
My NMS chip has been faultless
Old Aug 16, 2008 | 10:41 AM
  #69
Jim Galbally's Avatar
Jim Galbally
what problems?
you cant blame things like dodgy plugs and leaky injectors on the ECU software... rofl
Old Aug 16, 2008 | 10:49 AM
  #70
markk's Avatar
markk
but never as fuel efficiant as closed loop
Old Aug 16, 2008 | 11:05 AM
  #71
SumpNut's Avatar
SumpNut
It's probably allready been checked or mentioned, but doesnt he closed loop cut out if it detects movement on the TPS, maybe if its not set to fully closed on the throttle?
Dan
Old Aug 16, 2008 | 11:47 AM
  #72
Billabong's Avatar
Billabong
Was the car all warmed up, as the oil temp is only showing 25 Degrees?
Old Aug 16, 2008 | 12:17 PM
  #73
Stu @ M Developments's Avatar
PassionFords Creator
Yeah, every manufacturer in the world since 1992 (Any many before in USA and Europe) are all fooking idiots. Pointless system.
Problems are NOT caused by closed loop systems. Every car in the world has had it fitted for over 16 years. Its tried and tested by ever manufacturere in the world and they still use it today. Even the saphs manufactured in late 1991 and ALL the Escort Cosworths had it as standard, as do all the Focus Rs, ST etc.
The problems are caused by faulty cars and owners not doing things correctly, as i get the feeling Matt may confirm...
Old Aug 16, 2008 | 12:18 PM
  #74
Dan
Give that man a prize. this is without doubt the most common problem we see when customers DIY the system and then complain it does not work.
Old Aug 16, 2008 | 01:05 PM
  #75
costina's Avatar
costina
Live long and prosper!!
If its always ran rich i'd change the cts as first point of call IMO it could just be out of range and not being picked up by the secs
Paul
Old Aug 16, 2008 | 04:12 PM
  #76
Matt Baxter
Back in black!
yep it was me that was at fault all sorted now tho thaks to Stu going through all the options of possible fuck ups I might of made
but like I said its all sorted now and i am getting over 80 miles extra to a tank so it sould pay for its self in no time at all
Thanks Stu for all your help it was/is much appreciated
Old Aug 16, 2008 | 07:02 PM
  #77
KSA-Cossie's Avatar
KSA-Cossie
Come on then matt,what did you do ??????
Old Aug 16, 2008 | 07:07 PM
  #78
Since I got closed loop, I defo noticed my fuel needle is moving way less, despite being a lot faster and harder driven, light takes around 20 secs to go out for heater.
Old Aug 16, 2008 | 07:20 PM
  #79
Matt Baxter
Back in black!
well it sort of like this
i am a twat
when i did wires on the tpsi put a new plug on and managed to put pin 1 in hole 3 ,pin 2 in hole 3 and pin 3 in hole 2
only found this after
i replaced every sensor with new so 1 silly fuck up cost me dear
Old Aug 16, 2008 | 07:25 PM
  #80
KSA-Cossie's Avatar
KSA-Cossie
Oooooops,least it's all sorted now m8,whats next for the saph then ?
