LPG
Old May 26, 2008 | 09:03 AM
flashpoint's Avatar
flashpoint
Default LPG
anyone out there running there RS on LPG,,,?
Steve
Old May 26, 2008 | 09:14 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
not an RS, but i plan to run my mondy on it very soon!
Old May 26, 2008 | 10:07 AM
jaimesdna's Avatar
jaimesdna
no but imo it is worth doing with 2days petrol prices. do a search on here, there is some threads on running cossys etc on it
Old May 26, 2008 | 10:10 AM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
A local place called Pemco Pitstop are an approved LPG fitter, and run their SWB Transit van complete with Cossie engine conversion on LPG. Seems to go and work well.
There's a guy on the MLR running his Evo on the stuff as well, and it's something I'm seriously considering having done around 400 odd miles recently in my brother's LPG converted Focus Zetec.
Depending on the miles you do, you could easily make the install cost back within the first year.
Very tempting.
Si
Old May 26, 2008 | 10:15 AM
timster's Avatar
timster
Was thinking of doing this to my cossie as well,would it affect the resale value though?
Old May 26, 2008 | 10:21 AM
JonnyBravo's Avatar
JonnyBravo
It shouldn't affect resale value tbh.
I recently done a rally course with Phil Price and he runs all his cars on LPG, Escort Cossy, WRX and various other cars.
Even if your paying forecourt prices for LPG its still a lot cheaper to run a car on than diesel and that doesn't look to be changing either, since the huge rise in fuel costs we have had loads of enquiries.
Old May 26, 2008 | 10:22 AM
TIFF's Avatar
TIFF
Chasing Radders
My Audi A4 is on LPG..............its great
timster's Avatar
timster
You do conversions mate?
Old May 26, 2008 | 10:29 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
lpg on an evo would help with those horrendous fuel bills!
what stage of tune is the evo running at thats been converted?
Old May 26, 2008 | 10:32 AM
JonnyBravo's Avatar
JonnyBravo
yes I do mate.
Old May 26, 2008 | 10:33 AM
timster's Avatar
timster
Have you done any performance cars?
Old May 26, 2008 | 10:36 AM
Si B's Avatar
Si B
Pass I'm afraid Only saw a bit in his Avatar or similar saying he was LPG'ed!
From what I've heard, LPG is good / great for turbo converted cars... but not sure what the reasons are - expect Johnny Bravo could confirm. Something to do with being more det resistant IIRC.
Very tempted to do it, just don't really have Ł1.5k+ lying around to pay out initially.
Si
Old May 26, 2008 | 10:38 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
LPG is a LOT higher octane, so obviously that lends itself well to a lack of det on a turbo car.
You obviously need a quality install though with a fully mappable system.
Old May 26, 2008 | 10:39 AM
JonnyBravo's Avatar
JonnyBravo
Loads, 550hp F150 Truck probably being the most powerful.
We probably wouldn't get involved with a Cossy as we tend to work on more modern vehicles which are less likely to have hidden problems and less mileage, have a look at www.gastech.org.uk for more info on LPG, you obviously won't find any info on Cosworths on there but you will get an idea of the sort of things we do.
Old May 26, 2008 | 10:43 AM
JonnyBravo's Avatar
JonnyBravo
One of the systems we use does allow you to map the engine properly, we don't actually need it to be that advanced but the feature is there if you wanted to look for more power on LPG.
Old May 26, 2008 | 10:44 AM
timster's Avatar
timster
Just done a google on my area for lpg prices and its averaging 54 pence a litre,with petrol 1.17 a litre it works out Ł2.45 a gallon for lpg and Ł5.31 a gallon for unleaded over say 10,000 miles averaging 27mpg:
Ł907 for lpg
Ł1966 for unleaded if fuel doesn't rise again
Old May 26, 2008 | 10:48 AM
JonnyBravo's Avatar
JonnyBravo
Petrol fuel costs will go up again, that I am sure of
Old May 26, 2008 | 10:51 AM
Chip's Avatar
Chip
Ł907 for lpg
That price difference is around half the price (2k) of the sort of conversion that me and jonboy are referring to roughly I believe, although im sure he can confirm or deny that
Old May 26, 2008 | 10:52 AM
timster's Avatar
timster
You're not wrong there
Old May 26, 2008 | 11:13 AM
JonnyBravo's Avatar
JonnyBravo
On average you will lose 2-3 mpg on lpg, conversions cost from 1750 + vat for a 4 cylinder to 2k plus vat for a V8, depending on power output depends on how many other small bits you may need.
The kits we use are what we fit to the new Transits for Ford, very well proven kit.
Old May 26, 2008 | 11:24 AM
Get a different ecu with triple map and run LPG on a cossie with whatever power you want.
Use ULTRASEAL and you don't even lose boot space, as no spare needed then, you ca even gain by removing spare and the foam piece above the spare wheel.
LPG in "certain" places as little as 38p litre, the only difference is it does NOT have a STENCH agent in it, as used for HEATING, so if you have gas heating maybe a switch over!!
The tiny amount of mpg lost is more than covered by oil that does not need changing so often.
My LPG xr4i used to do 25,000 miles between changes, and it was pretty clean when changed, as no carbon in it like you get from liquid petrol.
They do tend to run slightly hotter, but plugs also last a lot longer, they are MUCH MUCH smoother, will start from a frozen winters day cold start no problem(system dependant), are quieter too, you can smell a tiny lpg smell at times but only slight.
If you did not want to go different mappable ecy type you can get a AEB wolf "N", which is a spark advance unit, just for when on lpg.
Old May 26, 2008 | 11:30 AM
JonnyBravo's Avatar
JonnyBravo
Ultraseal ? tire weld ?
Totally agree with LPG vehicles running smoother though, my own cavalier is VERY smooth.
The BRC Sequent series of ecu's can do spark advances, its that system we fit to the new Transit
Old May 26, 2008 | 11:37 AM
Jasesapphy's Avatar
Jasesapphy
nexy year LPG is incurring more governement tax so, LPG will rise in price quite quickly
Old May 26, 2008 | 11:44 AM
JonnyBravo's Avatar
JonnyBravo
Where on earth did you read that ?
Do you not think that fuel is likely to get to Ł2 a litre which will still make LPG even more of a saving
Old May 26, 2008 | 11:52 AM
B16's Avatar
B16
Of course it will, the more people that change to LPG the government will just jump on the band wagon.
Old May 26, 2008 | 11:55 AM
JonnyBravo's Avatar
JonnyBravo
Don't bank on that, if fuel goes to Ł2 a litre and LPG only goes up slightly its still a MASSIVE saving.
The Government have no reason to tax it, its the Garages taking the piss, not the government.
Old May 26, 2008 | 12:41 PM
discodenkelly's Avatar
discodenkelly
bounce, bounce, bounce
My jeep runs LPG, if it didn't I wouldn't have it cos I couldn't afford it. When the capri is done that will have an LPG tank in the back aswell.
Old May 26, 2008 | 02:23 PM
Graham S1's Avatar
Graham S1
Thats something that doesn't often get mentioned on LPG kits. I remember my two Granadas I ran on LPG. When I changed the oil after 6000 miles, it came out virtually the same colour it went in.
Old May 26, 2008 | 02:59 PM
flashpoint's Avatar
flashpoint
for thoese interested in the DIY aproch take a look at this site http://www.lpg-kits.com/
Steve
Old May 26, 2008 | 03:04 PM
JonnyBravo's Avatar
JonnyBravo
I'd rather not go anywhere near that cheap stuff tbh.
It can be more hassle than its worth, like anything you get what you pay for.
Old May 26, 2008 | 03:11 PM
jaimesdna's Avatar
jaimesdna
jonnybravo
do you know or had any experiance with the vogas kit? thinking about getting one for the missus car (mk5 xr3i). are lpg kits very easy to fit & map & also to change from car to car when she changes her car. also whats the deal with the certificate of fitting, in the real world is it really needed?
Old May 26, 2008 | 04:16 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it's usually required by your insurer - although not necessarily when you take out the policy, they would definately want to see it in the event of a fire
Old May 26, 2008 | 07:04 PM
James's Avatar
James
see, i like the sound of this as i have a 3.9 v8 and 2.8 v6, but have too heard that prices of lpg are going to be going up alot soon. they've gone from about 40p to 65p ish a litre around here over about a year, which is a scary thought if prices continue to escalate in that way, imho cycling is probably the cheaper alternative.
Old Dec 28, 2008 | 06:41 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there is a wirte up in one of the recent ppc's where it explains that although it's got a higher octane rating, it's got a lower calorific value as it's measured in litres not kilo's
or words to that effect
i'll see if i can dig it up
Old Dec 28, 2008 | 06:54 PM
foreigneRS's Avatar
foreigneRS
Testing the future
but you overcome that dojj by boosting more and stuffing more of it in there as the higher octane rating allows you to
crazydan
Feb 23, 2009 07:35 AM
banhambuilt
Feb 26, 2008 03:22 AM
banhambuilt
Dec 13, 2007 09:07 AM
TIFF
17
Dec 2, 2007 11:44 PM
