LPG conversions on Fast cars........
Chasing Radders
I have an Audi A4 that is LPG....runs a treat and cheap as chips as you may guess....
Now i was looking at the LPG cars on E-Bay and there is a Seat Leon Cupra R with an LPG conversion
Will it still be a fast car even running Gas.......... As my A4, even though it is only a 1.8......Feels no different on Gas than on petrol....Slow as fuck on both
So basically, is it ok to run Fast cars on LPG...ie, Focus ST, EVO, Scooby, M3 ect ect ect
And if so.....why the fuck dont more people do it
May feel a slight decrease in power, but nothing dramatic.
Have seen it said some gain power.
I've an M3, and having high cylinder pressures it's ideal for LPG.
Downside is people bleating on about why you'd buy a fast car and do this....
There is a lot of ignorance to LPG imo, and it has moved on a lot lately, I think many still believe it'll kill your engine.
No problem whatsoever, I've converted a 500 hp F150, 480hp RS4 amongst loads of other turbo vehicles.
Infact I'm doing a 600hp supercharged Hummer in 2 weeks
The issue as mentioned is space for a tank. Not much point imo fitting a 50 litre tank on a 480hp RS4 !
Tiff- What kit have you got on yours ?
Audio specialist
Audio specialist
you will have an emulator to turn off your petrol injectors and tell your ecu that there is nothing wrong, if you have injectors they will be drilled and tapped into your manifold as close to the head as possible x 4 , or if you have the older type you will have a big gas tube going to the inlet pipe near the throtle housing, where ther will be a venturi type effort inside the pipe or sat on the front of the throtle body.
Ideally for performance purposes you want a LPG system that allows ignition control, the kits we use do have this function.
In all honesty though we have never had to use it and all of the bigger powered vehicles have been spot on.
mk3ste
17-10-2021 10:09 AM
Johnny Knoxville
30-09-2015 07:21 AM
SMILER258
28-09-2015 09:04 AM
