T5 Standard Gearbox - How much power can it take ?
max 450 bhp some peopel will say they do 500 bhp but not for long i should no as i have 511 bhp and it keep blowing the gear box so i say best to say 450 or be gental with 500 bhp but then wahts the point of haveing that power
My mates 3 door apparenty runs the box out of Rainbirds old Saph, dead standard iirc
Its since spent years in a 400hp 420lb ft 3 door being abused and has never missed a beat. Ok it whines like a straight cut now but it still works.
IF you can find a half decent T5 Dingy and you turn the power down a little then it should hold together, it might even be better than that Quaife you had in there
[quote="JonnyBravo"]Its since spent years in a 400hp 420lb ft 3 door being abused and has never missed a beat. Ok it whines like a straight cut now but it still works./quote]
hi joh n
thats because the bearings are fooked and it's on it's last legs
it's ready to break mate : thast the warning you get when it's starts whining
marco
hi joh n
marco
Its how the torque is delivered that breaks things.
Get karl to slow the torque curve a touch.. do you run a hydraulic clutch?
If you do you could put an inline valve in to cushion the gearchange.
with the gas on i've hit 550ftlb without breaking the box.
Lee
Lee
[quote="marco polo"]
Or it has no oil in it
hi joh n
marco
hi joh n
marco
JonnyBravo
pmsl!
pmsl!
How the fuck that car has stayed so reliable I'll never know
A friend of mine used standard T5 for 2 years, using semi-slick tires and 677hp and NO problems whatsoever. Chaged it for a gearboxman kit, but the original never failed.
I`ve seen boxes last for 7-8 year with bad whining so I would not panic about a little noise
Ive found that above about 400 hp the gears in the T5 actually dissapear when making a change flat out , its bad enought that the ratios are shit but on several occasions ive lost places when trying to find 3rd in particular , bloody things !
I havent broken a box yet but have had two that sounded straight cut
One so bad that you could hear the car way before you saw it
I have ran over 2.5 bar on a T4 so that must have given the box a very hard time.
Its starts by getting noisy on overrun only after a few hard runs but gradually gets so it whines all the time.
Both boxes changed up and down gears well and both were fitted with the same quickshift.
My new getrag box is so slick comapared to the T5 alothougth with a slighty longer change
James Porter
28-10-2015 01:17 PM
Jack and the Beanstalk
13-09-2015 04:46 PM
track.focus'd
12-08-2015 06:53 PM
