Wireless Network Security...help!
Old Jan 4, 2008 | 01:33 PM
Munch's Avatar
Munch
Mr. Sparkle!
Default Wireless Network Security...help!
Right guys, had to Set up a new Network as my last one went tits up, well the routor did...
I need to know which is the best security out of this list...
WPA-PSK (no server)
128bit WEP
64bit WEP
WPA (with radius server)
this all means fuck all too me...help!
Old Jan 4, 2008 | 01:36 PM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
Use WEP thats the most common.
Old Jan 4, 2008 | 01:38 PM
Munch's Avatar
Munch
Mr. Sparkle!
there's 2, 128bit WEP & 64? which one
Old Jan 4, 2008 | 01:41 PM
Sunil_FiestaRS1800
either will do mate. 128 bit is more secure.
WPA is newer and more secure than WEP but i think you get a bit of a performance drop
Old Jan 4, 2008 | 03:01 PM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
Use a wep key mate- just like a pin no.
Old Jan 4, 2008 | 03:03 PM
Munch's Avatar
Munch
Mr. Sparkle!
cheers guys, il give it ago
Old Jan 4, 2008 | 03:13 PM
timb551's Avatar
timb551
depends on what you have the other side of this wireless network mate. wep takes about 8 seconds to crack if someone wanted to. WPA is where to go but a lot of slightly older devices dont support it.
Old Jan 4, 2008 | 03:14 PM
timb551's Avatar
timb551
this might help.
WEP vs WPA
I’ve been asked by a few friends lately about securing their networks and whether it really matters if they use WEP or WPA.
I will go over briefly what each is, and what the major differences are.
WEP:
Wired Equivalent Privacy. Originally intended to give you the same or similar level of security as on a wired network, but it didn’t quite work out that way.
In basic layman’s terms, WEP works by using secret keys, or codes to encrypt data. The Access Point and the client must know the codes in order for it to function. It uses either 64 bit or 128 bit keys, though the added security from the larger number isn’t as much as you would think.
The actual user keys (codes) are 40 bits and 104 bits, with the extra 24 bits used by something called the Intialization Vector (IV).
The encryption is created by taking the IV and randomizing it for each packet, while keeping the secret code the same. The AP and the client decrypt and retrieve the message/data and all is right in the world, in theory.
Problems:
* There is no limit on using the same IV value more than once. This makes the encryption vulnerable to collision-based attacks.
* Because the IV is only 24 bits, there are only ~16.7 million possible variations. Sounds like a lot, but it’s quite small in the cryptography world.
* Master keys are used directly, when they should instead be used to generate other temporary keys.
* Users don’t change their keys very often on most networks, giving attackers ample time to try various techniques.
If you have nothing else, WEP is better than nothing of course, but I wouldn’t trust extremely sensitive data with it.
WPA:
Wifi Protected Access. It bridges the gap between WEP and the upcoming 802.11i standard, and is implementable via firmware upgrades in older hardware. WPA uses Temporal Key Integrity Protocol (or TKIP), which is designed to alow WEP to be upgraded through corrective measures that address the existing security problems.
Advantages over WEP:
* IV length has increased to 48 bits from 24 bits, which allows WPA to achieve over 500 trillion possible key combinations.
* IVs are now better protected through the use of the TSC, or TKIP sequence counter, helping to prevent the re-use of IV keys.
* Master keys are never directly used.
* Better key management
* Impressive message integrity checking
I have not gone into the Enterprise level of WPA, which is actually intended to be used with something called a RADIUS server for access control. Most home users use what is called WPA-PSK, which is for use on smaller networks that need good security without the extra cost and configuration. WPA and WPA-PSK use the same encryption methods, however.
Future:
WPA2 (802.11i):
WPA2 features upgrades to WPA to make it even more secure.
* WPA2 uses AES (Advanced Encryption Standard) to provide stronger encryption.
* There are specific solutions for Enterprise and Personal use. Enterprise uses IEEE 802.1X and EAP to provide authentication. Personal uses a pre-shared key, or password.
* WPA2 still creates new session keys for every assocation, the benefit over WPA being that the keys used for each client on the network are unique and specific to that client. Every packet sent over the air is encrypted with a unique key and avoids re-use.
Old Jan 4, 2008 | 03:24 PM
Jonzy's Avatar
Jonzy
I wouldnt bother using fuck all at home tbh. Just look for the option disable ssid broadcast and use mac control/filtering instead.
Old Jan 4, 2008 | 03:51 PM
scottg17's Avatar
scottg17
you can set up a basic 64bit wep and mac filtering... this will only allow certain devices to connect to the router...
You will have a mac address on the wireless card... looks similar to this
e.g:
a1:d5:9o:mn:cy:a8
youd then set the router so it will only allow that device to connect to it
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
TrickyDicky
Jul 25, 2004 08:22 PM
AlexF
Jul 7, 2004 09:38 AM
