2wd cosworth fuel pump problem PLEASE HELP.....
Old 22-06-2007 | 10:47 AM
B13 JUS's Avatar
B13 JUS
Default 2wd cosworth fuel pump problem PLEASE HELP.....
my saph is in the paint shop and the guy who is painting it has gone to start it, it fired up then died and in won't start again but was fine when parked up
i've had a look and found out there's no power to the fuel pump.... it will start by putting a live from the battery to it.
i've checked all fuses and the cut of switch in the boot.( which i think is ok as its pressed in)????
does any 1 know which relays to check or anything else to check???
Old 22-06-2007 | 10:49 AM
abdr500's Avatar
abdr500
should be a yellow relay near the ecu
Old 22-06-2007 | 10:54 AM
B13 JUS's Avatar
B13 JUS
cheers mate is there any other relays in the fuse box that runs the pump or is that the only 1???
could it be anything else??
Old 22-06-2007 | 10:57 AM
foreigneRS's Avatar
foreigneRS
Testing the future
when you say you have checked all fuses, does that include the 2 relays and fuses for the ecu & fuel pump behind the passenger dash as abdr500 says
Old 22-06-2007 | 10:59 AM
abdr500's Avatar
abdr500
this shows 1 main relay and it also sow the fule pump relay they should be yellow cheack both of them or you could bride the fuel pump one to see if it make the fuel pump come on
Old 22-06-2007 | 11:03 AM
B13 JUS's Avatar
B13 JUS
no mate i have'nt checked them just the 1's in the fuse box... i'll check both relays and fuse's near the ecu and see how it goes.
thanks for you help guys
Old 22-06-2007 | 11:09 AM
Stu @ M Developments's Avatar
PassionFords Creator
Check the cutout switch first. Maybe he had a bit of axle trap moving it about...
Old 22-06-2007 | 11:50 AM
foreigneRS's Avatar
foreigneRS
Testing the future
top marks for being helpful as always stu but you're obviously far too busy as you didn't read the first post properly
Old 22-06-2007 | 11:51 AM
B13 JUS's Avatar
B13 JUS
sorted now... it was the fuse beside the yellow relay where the ecu is.
cheers again guys saved me some money
Old 22-06-2007 | 12:51 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 01:31 PM
kosienutter
31
22-08-2015 10:55 AM
41
21-08-2015 07:47 AM
dlwarrior
05-08-2015 11:19 AM
CabrioTurbo
01-08-2015 12:04 PM
