Am i lucky or unlucky, place your bets..... (engine failure)
Old 19-04-2007, 04:09 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Default Am i lucky or unlucky, place your bets..... (engine failure)
Well the snotty old YB I through into my 3door as a temporary measure has died, but the question is, can it be resurected?
Symptoms:
Engine still runs fine, goes really well
Water is coming from between the block and the head
The coolant is full of oil (lovely brown sludge)
I figure its one of the following:
a) Head gasket
b) Cracked Block
c) Cracked head
Its a 205 block, on ARP's
Going to pull it apart tonight, but what does everyone think will be the outcome, will it be back together tomorrow evening with just a new headgasket, or am I going to need a new block and/or head
*jap accent required for next line
Prace Bets Now...........
Old 19-04-2007, 04:16 PM
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
...are you saying its spraying out?..is it the rear corner exhaust side as its common there...but sorry to say your block has cracked between the head bolts
Old 19-04-2007, 04:18 PM
Smit
The 60ft Launch King
Smit's Avatar
Head cracked between valve seats......
Deleted by Request
Former Sponsor
..to add did you put the head on...if so what did you torque the arp's to and was it with or without moly grease?
Old 19-04-2007, 04:22 PM
dave cos4x4
dave cos4x4's Avatar
i would say its cracked too.
Old 19-04-2007, 04:47 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
ARP itous by the sounds of it
Old 19-04-2007, 05:56 PM
Chip
Chip's Avatar
Just took the head off, looks like its only the gasket.
Gone between the oil and water ways but not the combustion chamber.
Probable cause by the looks of it is corrosion, which will be my fault as I ran in the summer without antifreeze in it for ages.
Lesson learned there then, lol
Old 19-04-2007, 05:59 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
t t t.....u do need the big A/F in a cos lump.......shame on u...get it fixed and get it abused
Old 19-04-2007, 06:22 PM
Chip
Chip's Avatar
Hopefully get it back together tomorrow night as busy during the day
I already knew full well about the antifreeze, but you know what its like if you have none of it on the shelf and you change a hose and then want to use the car, lol
Phil, cant remember what torque settings I used for the ARP's, whatever I was recomended off here at the time, think I used the grease last time but if I havent got any spare this time I will just do it with the oil setting (is it 100 for oil and 80 for arp lube IIRC?)
Will get on the lookout for the bits to rebuild the 200 block up properly as soon as the nova and calibra are finished (hopefully in june) as im sure although I was lucky this time, its only a matter of time for this engine.
bigryrs
28-03-2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
Quick Reply: Am i lucky or unlucky, place your bets..... (engine failure)
