Heatwrapping exhausts,is it worth it ?
the down pipe has set the bulk head on fire after long periods of full throttle and the fuel has also been heated up after long periods of flat out running so just trying to help this
what stops it going brittle and corroding/falling off? I've seen a few where its been on a few months and is hanging on for dear life
If you spray this on, it turns it into something like a plaster cast and stops it from going brittle.
Originally Posted by abdr500
rapping your exshsut manifold can also reduce lag time
when turbo and exhaust are up to temp the lag will be the same regardless of wrap or not.
Originally Posted by B9KOS
Originally Posted by KSA-Cossie
How far did you go big boy ??!!
Went down to where the downpipe splits into two ( I've got a Magnex ). near the front prop
Thanks for the reply m8.
my ashley 4branch i fitted yesterday...using jubilee clips untill i can find somewhere that sell the metal ties...
(using tape to stop it from coming undone till i fitted the jubilee)
Guest
Posts: n/a
i wouldnt wrap the whole exhaust.
just the important parts, i.e next to sump/gear/and maybe tank.
Rod did this on his saph and apparantly the exhaust expanded/lengthed by like 2-3 inches due to heat.
Bloody hell Ryan thats mental
I wrapped this one till it had cleared the sump, itchy irritating stuff but should do the job nicely.
I was considering wrapping it half way under the car too but I doubt it would make any difference and would easily cost another Ł60
