removing engine from 4x4 cossie (help)
Old 12-10-2006, 07:22 PM
radiant red
radiant red's Avatar
Default removing engine from 4x4 cossie (help)
in the process of fitting a new block and im struggling to remove the block with sump attached
subframe is loose gearbox is off and drive shafts etc but its sooooo tight
is it best to remove sump??
had an hour on it this aft im doing it on the floor with the engine lift
help please
Old 12-10-2006, 07:23 PM
xr4x4rs
xr4x4rs's Avatar
easiest way is drop everything from underneath mate
never took one out from the top as it looks like too much hassle
Old 12-10-2006, 07:24 PM
radiant red
tell me about it im concidering rebuilding the fooking lot and pushing it on two poster
unles i can get it high enough without bending the twat!
Old 12-10-2006, 07:48 PM
Stu.H
Stu.H's Avatar
Good luck mate, not something ive tried.
Old 12-10-2006, 07:50 PM
SPADGE
SPADGE's Avatar
Loosen the engine mounts from the crossmember as they get very tight even with the top nuts removed
Old 12-10-2006, 07:53 PM
radiant red
only need my subframe to move forward about a foot to clear diffs
wes
wes's Avatar
Default Re: removing engine from 4x4 cossie (help)
Subframe needs to be off, not loose, i.e. no bolts holding it to the chassis, use a jack to hold up the subframe, remove the 4 bolts, and then let the jack down, don't forget to undo the steering coupling next to the bulkhead, + good luck!
radiant red
gonna have a crack at moving subrame out tom as engines on crane
Old 12-10-2006, 07:55 PM
radiant red
yep coupling removed and frame is dangling and thank you
dave cos4x4
dave cos4x4's Avatar
help please
is it still in the car...or have you got the lot out and just trying to split the block and sump.
Old 12-10-2006, 07:58 PM
radiant red
dave cos4x4
ive removed head etc just trying to remove the block from the engine bay
Old 12-10-2006, 08:00 PM
Lee Reynolds
Lee Reynolds's Avatar
new block....not in the one ya just bought surely
Old 12-10-2006, 08:02 PM
radiant red
Lee Reynolds
aye she cracked the next day
just my luck!
oh and i replaced gasket before i realised
Old 12-10-2006, 08:06 PM
silky16v
Get on That!
silky16v's Avatar
remove front diff makes it easier to lift out
Old 12-10-2006, 08:08 PM
Lee Reynolds
Lee Reynolds
just my luck!
fooking hel mate thats shit i remember ya thought HG had gone....bugger
Old 12-10-2006, 08:09 PM
radiant red
but is it not integral with the sump??
Old 12-10-2006, 08:11 PM
radiant red
Lee Reynolds
just my luck!
well tbh mate it was always in back of my mind but its not the thing you want after 200 miles
didnt see the crack untill next day due to it rusting
Old 12-10-2006, 08:12 PM
wes
wes's Avatar
You should have left the head on and removed all a in one, i did it that way once last year, never again! I struggled my nuts off to remove it, it just wouldn't come out for some reason! Try a crow bar in the between the engine and gearbox, work both sides until it is totally free, do you have another jack supporting the gearbox?
Old 12-10-2006, 08:14 PM
radiant red
i removed head to inspect mate
the box is supported and well clear as i have removed cooler and rad
if i can remove diff it would be a piece of piss or clear subframe
Old 12-10-2006, 08:26 PM
xr4x4rs
xr4x4rs's Avatar
Old 12-10-2006, 08:31 PM
radiant red
looks like its taking off
ya live and learn mate
Old 12-10-2006, 08:33 PM
xr4x4rs
xr4x4rs's Avatar
but also gives you an idea for nxt time
id be going to find a trolley aswell
as you can do it this way refitting the lot aswell
except you will have the engine cradle on so it can be lifted straight up
Old 12-10-2006, 08:34 PM
radiant red
i might push it on the two poster and lift the car over it
Old 12-10-2006, 08:35 PM
melzieann
melzieann's Avatar
i always drop the lot out at once engine, subframe, suspension gearbox ect,
then once out rip the box off undo engine mounts and lift off subframe and there you have it
Old 12-10-2006, 08:39 PM
wes
wes's Avatar
Can you not put the head back on as a temporary measure? If the gearbox is clear, and the subframe removed from car, then it can't foul anything else
I have done it this way about 6 times in the past 2 years with my own 4x4, only time i struggled was when i didnt have the head on (because i had bent all my exhaust valves )
Removing the diff in the car is a PAIN in the RS!
Old 12-10-2006, 08:42 PM
radiant red
why would i put head back on mate?
i have the straps around the engine mounts to lift the block out but the diff is fouling the subframe
surely i can move the sub forward if i remove p/s pipes
Old 12-10-2006, 09:02 PM
wes
wes's Avatar
To give you more leverage, those lifting eye thingies attatched to the head were designed for this very purpose Will take about 2 minutes to put it back on and nip up the old head bolts
If you remove the p/s pipes there is nothing to stop you removing the subframe completley, I hate taking the engine out of mine
i'm sure you will get it done
Old 12-10-2006, 09:05 PM
radiant red
"I hate taking the engine out of mine "
regular thing
Old 12-10-2006, 09:09 PM
melzieann
melzieann's Avatar
i would put on ramp and drop the lot mate i have done loads it takes me 1 hour and 45 min from start to engine on the floor, put to axle stands under subframe take car down on them undo subframe bolts steering u-jay and calipers off discs then last thing undo top shocker mounts take car up on ramp job done
Old 12-10-2006, 09:14 PM
radiant red
this is by far the easiest option
trouble is im doint it at work and dont wanna take one of the lifts,where pretty busy at the mo but i could do that over weekend and replace the subframe etc whilst im building the engine so it can be pushed out.
think im gonna go in early and rebuild it
Old 12-10-2006, 09:15 PM
radiant red
i dont fanct lifting front end 3 foot on stands
but then its another option
Old 12-10-2006, 09:20 PM
melzieann
melzieann's Avatar
i meant with the subframe in place bring the car down to with in a mil of the stands undo bolts so engine, frame ect sits on stands then take car up, hook up engine hoist undo mounts lift engine off then take car back down bolt frame in and shockers, car off ramp push outside
Old 12-10-2006, 09:22 PM
radiant red
i think this is how it will happen bollocks to struggling when theres no need
thanks for help yorl
Old 13-10-2006, 07:20 AM
Kevin B
Kevin B's Avatar
We removed my engine out of my 4x4 Saph Cossie about 8 weeks ago and thankfully didnt have any of these problems
Took gearbox out, removed head, disconected all plumbing (water, oil, pas etc) then just lifted the block, sump and front diff off the engine bed straight out of the top, absolutely no bother... just need to lift it out with the bulkhead end down slightly so the front clears the engine bed.
Old 14-10-2006, 12:08 AM
radiant red
well i dropped the whole thing had it out within an hour of this option
just picked new block up so this time next week she'll be purring
Old 14-10-2006, 06:35 AM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Sorry your block cracked mine did as well this year
Hope its all up and running for you soon
Steve.
Old 14-10-2006, 07:57 AM
radiant red
Steve.
bastard intit
its the worse possible scenario but at least i get to do a full rebuild whilst its in bits not that it needed it
track.focus'd
12-08-2015 05:53 PM
MARKYMARKONE
02-08-2015 09:33 PM
CabrioTurbo
01-08-2015 11:04 AM
lockie
31-07-2015 10:03 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: removing engine from 4x4 cossie (help)
