Strange Boost Problem
Old Sep 25, 2006 | 07:52 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Default Strange Boost Problem
Cambelt on my cossie snapped a couple of months ago (long arse story so wont bore you with it). Bent 6 valves. Mark kindly let me do all the work myself at his new premises So lapped 6 new vales back in and put the car back together. Fired it up all is ok. Mark took it for a test run and it wouldnt boost over 2 bar. Before the cambelt snapped we saw 2.4 bar. Absolutely nothing has changed, so am confused as to why the boost would not be there. Mark had to give the acutator a good old wind to get the boost to 2.2 bar. I want my original boost figure back
Anyone had this problem before? The actuator is -34 and hasnt even covered 500 miles. Could a weak spring be casuing this, or can anyone else shed some light. I defianltely have no boost leaks, thats all been checked.
Any ideas?
Old Sep 25, 2006 | 08:38 AM
CossieRich's Avatar
CossieRich
anyone
Old Sep 25, 2006 | 08:39 AM
Cossie Helen's Avatar
Cossie Helen
Awww
Old Sep 25, 2006 | 10:05 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Did any shrapnel from the valve / piston "coming together party" damage the exhaust blades of the turbo?
Old Sep 25, 2006 | 10:09 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
or cause the wastegate to not seat correctly.........
Old Sep 25, 2006 | 10:29 AM
CossieRich's Avatar
CossieRich
No Mike. All valves were intact and together just 6 of them were bent Pistons had no markings whatsoever on them so it looks like the pistons just kissed the valves.
Old Sep 25, 2006 | 10:31 AM
CossieRich's Avatar
CossieRich
Pretty sure the wastegate penny is properly seated as there seems to be no problem with building the boost up (which wouldn't be the case if the wastagte wasnt seated properly i asume), it just doesnt boost as much as before
Old Sep 25, 2006 | 10:33 AM
JTECH James
Passion for Fords!
wonder if the valve piston contact damaged the hydaulic lifters, not opening fully now?
funny one this......
Old Sep 25, 2006 | 10:35 AM
CossieRich's Avatar
CossieRich
It is a funny one isnt it. I thought maybe the actuator had gone weak due non use for 3 months
Old Sep 25, 2006 | 10:37 AM
JTECH James
Passion for Fords!
i suppose it is possible, if everything is set up the same it must be that.... verniers dialed in the same as before?
Old Sep 25, 2006 | 10:41 AM
CossieRich's Avatar
CossieRich
Yes mate, all exactly the same, just 6 new valves. Same thickness of cometic headgasket (new of course), same cams, etc
Old Sep 25, 2006 | 10:45 AM
JTECH James
Passion for Fords!
must be the actuator then.....
unless the valves hit so hard it bent the con rods and you now have a 5.6:1 cr
Old Sep 25, 2006 | 10:48 AM
CossieRich's Avatar
CossieRich
rofl I think there would be damage to the pistons if that had happened, but there were no marks. thank chrsit for valve pcokets
Old Sep 25, 2006 | 02:15 PM
CossieRich's Avatar
CossieRich
anyone else got an input before i go spending on a new actuator?
Old Sep 25, 2006 | 03:04 PM
YBP's Avatar
YBP
Skimmed head?
Old Sep 25, 2006 | 03:11 PM
CossieRich's Avatar
CossieRich
nope, didnt do that. Nothing has been skimmed. it all went back the same as it come off
Old Sep 25, 2006 | 03:18 PM
Dicko&Vacant's Avatar
Dicko&Vacant
have you got the pipes on the right way from amal valve to turbo to actuator etc
Old Sep 25, 2006 | 03:25 PM
CossieRich's Avatar
CossieRich
I have mate. The pipe with the restrictor in in goes to the turbo and the other one to the actuator. I really am begging to lose the will to own a cossie recently.
Old Sep 25, 2006 | 04:35 PM
YBP's Avatar
YBP
How do you know 100% there isn´t a boost leak? How did you check it?
Do a sylinder leaktest too just to be certain.
Old Sep 25, 2006 | 04:41 PM
YBP's Avatar
YBP
Here you are jumping to conclutions. You don´t know if it´s seating proberly if you haven´t checked.
Asuming is the mother of all f*ck up´s when it comes to troubleshooting.
I think there will be no problem building boost with a small leak. But getting very high boostpressures as you are running aren´t very easy with internal wg.
Old Sep 25, 2006 | 04:53 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Hi Rich,
I think the actuator on my T38 is a -34.
I can post it to you if you want to try it (its brand new unused)
Speak to me on MSN mate
Steve.
Old Sep 25, 2006 | 04:57 PM
...put a bleed valve on if that dont give you 3bar i dont know what will
Old Sep 25, 2006 | 05:08 PM
CossieRich's Avatar
CossieRich
Thanks for the replies all. Right,
Before the cam belt snapped, the peak boost was 2.4 bar. So there can be no way that the wastegate is leaking, seeing as the car stopped instantly and didnt get started until the engine was back together.
The boost pipes cant be leaking just from taking them off and putting them back on again, but i will do a leak test to make sure.
there is only 2 things left. Either the turbo is fucked, or the actuator has gone weak, but i just cant see it. 30 secs before the belt snapped, i had full boost, of that there is no doubt.
Steve. MSN in about an hour my friend.
Phil, we took the pipe off the actuator, therefore giving basically full boost with no control, and it made no difference.
Old Sep 25, 2006 | 05:14 PM
YBP's Avatar
YBP
Plenumgasket blowout when the engine went pop?
Tried with startgas to search for leaks?
Old Sep 25, 2006 | 05:16 PM
.....oh ok...i ruled out actuator because i thought Mark may have already told you that if it was.....to me though personaly deffo actuator!
Old Sep 25, 2006 | 05:17 PM
CossieRich's Avatar
CossieRich
Plenum gasket re-newed when put back together mate.
Old Sep 25, 2006 | 05:20 PM
CossieRich's Avatar
CossieRich
We basically run out of time, and Mark didnt charge me for having my car there and has been very decednt when coming to a figure of how much i owe him for timing up my cam and trying to source this problem, so i didnt want to take the piss and outstay my welcome, even though Mark said it was not a drama
He said either my turbo or actuator is at fault. Cheapest thing to try 1st is the actuator, although thats only covered 500ish miles
Old Sep 26, 2006 | 10:43 AM
Try putting a spring from the actuator mounting point on the turbo to the wastegate, to try and encourage it to stay shut, that should rule out the actuator going weak.
If it still wont make boost then, it seems likely the turbo is damaged
Old Sep 26, 2006 | 10:45 AM
CossieRich's Avatar
CossieRich
Cheers Chippa,
every idea helps
Old Sep 26, 2006 | 12:18 PM
CossieRich's Avatar
CossieRich
I did Dave yes.
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
