Whats the max can a T34.48 can realistically make?
#125
saff is working!!!...atm
Originally Posted by JTECHSAFF
The transmission has shite itself twice already!
And three front diffs! : cry:
#129
Almost there!
Rich, the L8 AND P8 ecu's are more readily live mapped due to ease and available software.
going by past posts from Simon, most the cossie rang of ECU's are live mappable - with the correct equipment.
Simon, gladly correct me if im wrong
#132
Kelv,
Spot on.
CossieRich,
A brief explanation....
Any ecu can be live mapped with the right equipment if the ecu
doesnt have onboard facilities to do so.
This is done with an EPROM EMULATOR (cost about Ł400-Ł1000)
But you need to know how and where the correct memory locations are.
This is the bit that costs the money in experience/skill etc...
All OEM cosworth weber ecu.s once mapped, need an eprom programmer
to make the changes permanent. (Ł250 - Ł800)
L8 and P8 with PECTEL software can be adjusted on the fly with fuel and
ignition trims without any special equipment but will need a programmer
to make changes permanent as above as these adjustments are lost
when the power is removed.
After market ecu's contain FLASH memory which do not require power
so when live mapped, the data is permanent and dont require any extra
equipment except a PC and a lead.
Spot on.
CossieRich,
#133
Almost there!
mmmmm. a bd10 exhaust cam, bd12 inlet cam, set of vernier pulleys, greys, t3.48
sounds good quoting lots of inlet and exhaust parts but it doesnt always equate to more power!
#134
Passion for Fords!
i would probably go for just a bd12 inlet cam and light blues, if that is do-able, may make the transmission last a weeee bit longer , id be happy if i could just make it quicker than a stage 3 car ,too many other cars can run with me at the mo, i just want a little bit extra......
#135
Originally Posted by CossieRich
JTECHSAFF
so....... i run a t34.48 , 7.2:1 cr, at the mo running standard cams, 500 cooler, flowed head, Stu's closed loop stage 3 chip, what should i do next for more power im bored!!!
Thats with a standard engine but he used siemems 'black' 55lb injectors instead of greys
#136
Did Someone Mention TUV
Originally Posted by SECS
Kelv,
Spot on.
CossieRich,
Spot on.
CossieRich,
#137
Originally Posted by b19bal
tbh be fair to pete hes not talking shite, you lot are just assuming stuff and going from there
with a ported head/cams and .48 t34 the green injectors are maxed out !!!!!
or they was on mine meaning u could have ran more boost on blues ect
you lot are just assuming hes refering to 26psi and just slap greys in the car
you aint beeing fair to him being honest
Its my cars Pete's talking about, as i see it the oringinal question was what power can a T34.48 make. Answer around 380bhp max.
Thats all Pete said,greens can't do it light blues can. ONLY A COMPLETE AND UTTER TWAT WOULD THINK 'FOOK ME BEST TELL HIM HE NEEDS A RE-MAP TOO' BECAUSE HE MUST BE THAT THICK NOT HAVING POSTED 25 BILLION TIMES
Ahhhhhhh but then the wisdom of L6 can't be mapped......quality
TPM961
15-01-2018 10:50 AM
cossirob
16-09-2015 07:39 PM
