Zetec Turbo Rev Limit - Whats yours set at?
Old 11-07-2006, 10:36 AM
AustenW
AustenW's Avatar
Default Zetec Turbo Rev Limit - Whats yours set at?
I've set mine to 7800rpm as it was just hitting the limiter in forth over the quarter at 7200
Just wondered what others are running?
Old 11-07-2006, 10:59 AM
Garage19
Garage19's Avatar
I have set the one on the white 3dr sierra at 7000rpm to start with. As far as i can remember the redline on a stock mondy is 6500rpm???
Do you have a steel crank in yours??
Old 11-07-2006, 11:02 AM
Rolls
Rolls's Avatar
Surely this is shuold be governed by the engine components rather than rasing it just to have few gear changes up the quater...?
AustenW
AustenW's Avatar
All Steel
Old 11-07-2006, 11:03 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
std zetec is 6200, mine will be 7000 with the turbo
Old 11-07-2006, 11:05 AM
Garage19
Garage19's Avatar
Originally Posted by AustenW
All Steel
Flash bugger! How much did your crank set you back? Was it from the states?
Are you going to go to Ford Fair this year? Would love have a nose round your car in the flesh.
Old 11-07-2006, 11:08 AM
Garage19
Garage19's Avatar
Default Re: Zetec Turbo Rev Limit - Whats yours set at?
Whats the mean piston speed in m/sec @ 7800rpm??? We can compare it to some other engines with similar designs.
Old 11-07-2006, 11:12 AM
AustenW
AustenW's Avatar
The engine stands me at a fair bit. Crank was sourced in the UK.
I will be at Ford fair on the Sun, Racing at USC at pod on the Fri and Sat so will drive up on the Sun if I dont break something.
Not done the calculations for this engine yet
Old 11-07-2006, 11:14 AM
Garage19
Garage19's Avatar
Cool, see you then.
Stock 88m stroke?
Old 11-07-2006, 11:15 AM
AustenW
AustenW's Avatar
Yes 88mm stroke
Old 11-07-2006, 11:19 AM
Garage19
Garage19's Avatar
22.88 m/sec.
From memory, when i had the long stroke motor in my super mono race bike i used to run 25/26 m/sec.
F1 engines run about 27 m/s.
Old 11-07-2006, 11:42 AM
reality
reality's Avatar
There is only one true way to see what the limit is.. and it's an expensive way..
Old 11-07-2006, 11:46 AM
GARETH T
GARETH T's Avatar
Originally Posted by Garage19
22.88 m/sec.
i think F1 engine run even higher than that now,,,, cant remember a number for it now though
Old 11-07-2006, 11:51 AM
reality
reality's Avatar
Well, F1 is about 40mm stroke @ 20,000rpm.. so go figure
Old 11-07-2006, 11:56 AM
Garage19
Garage19's Avatar
I just have, based on your figures, 26.6 m/sec.... as said above.
Old 11-07-2006, 11:58 AM
GARETH T
GARETH T's Avatar
im sure ive heard figures closer too 28m/s i could be wrong though
Old 11-07-2006, 12:12 PM
Garage19
Garage19's Avatar
I think there is a kinda limit buffer that they run into that is all to do with pecentage of the bore that can be filled with valve area and the physical limits of how fast you can move a volume of air through it.
Its not governed by material properties any more, as it was in the old days.
I have dragged that right out from the back of the grey cells so dont take it as gospel. If i have a spare min i'll look it up again.
robnock
21
13-05-2019 05:29 PM
Billy_RS
15
05-09-2015 12:04 PM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: Zetec Turbo Rev Limit - Whats yours set at?
