Titanium Con Rods
Old 11-07-2006, 10:39 AM
AustenW
AustenW's Avatar
Default Titanium Con Rods
Has anyone tried them?
Was there a noticable improvement in response?
Old 11-07-2006, 10:41 AM
Careful where you buy them!
A mate got a couple of sets on Ebay and i arranged to go halves with them on them.
When i inspected them they werent fit for purpose and we both ended up with some nice paperweights.
Old 11-07-2006, 10:49 AM
Ryan
Ryan's Avatar
Probably easier to get some machined from billet rather than going out and buying some.
Titanium billets arent that costly.
Old 11-07-2006, 10:52 AM
AustenW
AustenW's Avatar
Looking at the Arrow ones, there expensive but will be of high quality
Old 11-07-2006, 11:38 AM
Rick
Rick's Avatar
Aren't they very suceptable to fatigue, and only meant for very low mileages?
Old 11-07-2006, 11:43 AM
reality
reality's Avatar
If you want response, then go with a roller throttle body setup and pectel t6
Old 11-07-2006, 11:44 AM
GARETH T
GARETH T's Avatar
im sure the porsche gt3 has them as standard
Old 11-07-2006, 11:47 AM
Garage19
Garage19's Avatar
As do quite a few Ducatis.
Old 11-07-2006, 11:50 AM
GARETH T
GARETH T's Avatar
Rick
have you ever seen how many different alloy types there is of Titanium
Garage19
ah of cause,,,, i do know very little about big engines though
Old 11-07-2006, 11:53 AM
Rick
Rick's Avatar
The titanium has to be coated for crack resistance. The surface has to be treated very thoroughly in order to precent fatigue lines forming, or they will fail after a short mileage. They have 25% the elasticity of decent steel, which is why they tend to crack. The weight saving of a proerply treated titanium rod is 12% over a steel, and around 75% of the strength.
Defo suited to NA engines imo, i defo wouldn't bother.
Old 11-07-2006, 11:55 AM
Rick
Rick's Avatar
GARETH T
yea, loadsssss lol. new vette uses them too. It seems that there is something to be gained in terms of a little weight saving. But i just wouldnt trust one in a custom application if it's unproven.
Old 11-07-2006, 12:04 PM
Garage19
Garage19's Avatar
Surely if you use those figures then they would NEVER be worth using????
You are saying if you made two two rods to the same strength the steel rod would always be lighter!
May be it is to do with the fact that with titanium you can use more material to create stonger shapes/structure.
Old 11-07-2006, 12:05 PM
reality
reality's Avatar
There is a considerable difference between a manufacturer developing and designing a set of rods for a production car, and a few people on a forum buying generic rods from a.n.other company (even Arrow).. I wouldn't want to risk it personally, can't really see the need either..
Old 11-07-2006, 12:13 PM
Rick
Rick's Avatar
Garage19
Doug - they're the figures from an engineering paper, and yes they sound strange. I think it must be to do with the shape, but if u do two exactly the same - they are the figures that you get.
It seems that steel is stronger for lower rpm's, (sub 11k) and ti for higher rpm's.
Complicates subject
stevecfrst1
30-09-2015 05:18 AM
little bram
27-09-2015 07:45 AM
S3an
26-09-2015 11:39 PM
coscor86
20-09-2015 01:21 PM
Quick Reply: Titanium Con Rods
