The ZT is nearly finished (Ha ha - Mr Fudge)
Old 17-06-2006, 04:51 PM
Garage19
Garage19's Avatar
Default The ZT is nearly finished (Ha ha - Mr Fudge)
As you may know Dan (FF) is trying to build a zetec turbo 3dr and we have been trying to beat him to it. It has turned into a bit of a friendly grudge match.
We are getting close to finishing now so all i get from dan is "show me the f*cking pics"
I thought i would post them up here in case anyone else was intrested.
I just finished wiring in the MS Ecu this morning. Had to make an adapter to bolt on a different TPS as the 65mm (id) BMW535 TB we are using only had a throttle switch.
A couple of shots of the engine in the car.
and an arty farty one, looking through the TB in to the plenum chamber.
Old 17-06-2006, 04:53 PM
haz87
haz87's Avatar
Old 17-06-2006, 04:55 PM
turbo.jon
turbo.jon's Avatar
Old 17-06-2006, 04:56 PM
MAD EVO 4
MAD EVO 4's Avatar
Very nice bro
Old 17-06-2006, 05:13 PM
ECU Monitor Enthusiast
Nice any idea on estimated power ?
Old 17-06-2006, 05:20 PM
Garage19
Garage19's Avatar
400+ we hope. The turbo is a GT30r so easily capable of it.
It has all the right internals and the head on it is a new focus RS casting nicely worked by CNC heads. It really is one of the best head jobs i have ever seen. CNC machining of heads is certainly the way forward. Every port identical and designed on a computer simulation for optimum flow.
Just up to the monkey who is mapping it to get the best from it
Old 17-06-2006, 05:24 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Looking good
Old 17-06-2006, 05:26 PM
flax
flax's Avatar
you using the old squirter on it dude.
looks sweet.
Old 17-06-2006, 05:34 PM
Garage19
Garage19's Avatar
Yup, Megasquirt management.
Old 17-06-2006, 05:39 PM
Madbradz
Madbradz's Avatar
Ah man thats sexual
Old 17-06-2006, 05:40 PM
LOL @ Monkey mapper
Good luck, good feeling when its all your own work.
Cant beat tuning experience though as I found out....
I mapped my own car, then let a professional finish it.
Ended up with 54 bhp more and 3 psi less boost
Old 17-06-2006, 05:49 PM
Ryan
Ryan's Avatar
looks very nice mate
Old 17-06-2006, 06:04 PM
Garage19
Garage19's Avatar
Originally Posted by SECS
LOL @ Monkey mapper
Not all MY own work. I have done a fair bit of work on this car, but the cars owner has done most of the hard graft transforming the car from a 1.6 GLS.
Hopefully we will be going to Ford Fair in it and he can put a few decent times in up the strip.
Old 17-06-2006, 06:11 PM
Smit
The 60ft Launch King
Smit's Avatar
Nice one Doug!
Wierd seeing the turbo on that side!
Make sure ya get ya heat shield on there or melted paintwork you up!
Old 17-06-2006, 06:19 PM
Garage19
Garage19's Avatar
Ello Smit,
You have PM.
Turbine housing isn't actually that close to the inner arch, but i will be putting one on.
You still got the cossy?
Old 17-06-2006, 06:37 PM
That looks awesome
Whats with the 400bhp estimates though?
Surely with that sort of spec you are looking at 500+
Old 17-06-2006, 06:44 PM
Garage19
Garage19's Avatar
That looks awesome
True, but if i say 400 bhp the chances of being dissapointed are smaller
As its a zetec, its a bit of an unknown quantity.
Old 17-06-2006, 06:45 PM
PMSL
That will be like the 500 i want from my GT35R on 11mm lift cams with solid lifters at 8Krpm plus then mate
Old 17-06-2006, 06:47 PM
PS
Did i give you an address for that sump?
And how do i pay you mate!?
Old 17-06-2006, 06:50 PM
Garage19
Garage19's Avatar
Exactly. Guess we have both seen people making claims and looking like right numpties when they finally get it on the dyno.
Old 17-06-2006, 06:52 PM
Rs1
Rs1's Avatar
That look a quality piece of kit
Youve got the manifolds mixed up though,they go on the opposite ends mate
Old 17-06-2006, 07:00 PM
Garage19
Garage19's Avatar
PS
No, you had better PM me it. Cheque made out to Douglas Cook will be cool.
What you gonna run your cossie engine with now you have sold the secs?
Old 17-06-2006, 07:01 PM
Rick
Rick's Avatar
Looks cool. Is it the later or earlier Zetec? Earlier one has bad rod/stroke angle doen't it? And small bored compared to YB.
Old 17-06-2006, 07:07 PM
Garage19
Garage19's Avatar
Early zetec bottom end with late rods/pistons and a late solid lifter head.
Rod ratio is ok.
Yes, small bore (85mm) when compared to a YB. Engine is in fact under square. The small bore should help with a cetain amount of det resistance.
Old 17-06-2006, 07:10 PM
Rick
Rick's Avatar
be intersting to see the power Steel rods/forged pistons?
Old 17-06-2006, 07:13 PM
COMEDY DAN
No1 Blower.
COMEDY DAN's Avatar
That looks RUDE man
Old 17-06-2006, 07:16 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Looks teh part, best of luck with it
Old 17-06-2006, 09:31 PM
Mr C
Mr C's Avatar
Thats interesting mate, how do they compare to a YB, weight and power ets, 400bhp isnt too shy already, can they go big power like the YB?
Old 17-06-2006, 09:39 PM
luke89
Team HOTHOT!
luke89's Avatar
looks mad , im sure the limit on the crank is about the 500 mark from whta people have said before dose it run a dif crank ?
Old 18-06-2006, 10:37 AM
Garage19
Garage19's Avatar
About 15kg lighter. Its also a fair bit shorter. You can see how much space there is in the front of the engine bay.
Old 18-06-2006, 10:50 AM
DazC
DazC's Avatar
Good luck with finishing it off and mapping it!
Old 18-06-2006, 11:03 AM
Dan
Dan's Avatar
VERY nice indeed mate, looks like it's gonna be abit of a flyer
Old 18-06-2006, 12:49 PM
Iain Mac
Iain Mac's Avatar
How tidy is that without loads of wires and stuff in the way.
Old 18-06-2006, 02:40 PM
pee vee
pee vee's Avatar
Mate you are MILES ahead of fudgee lol
his has only just gone off to have the rust painted over
looks good! Will be interested to see how much power the beast makes!
dont know a lot about Zetec turbos!
Old 18-06-2006, 02:42 PM
Taylor
Taylor's Avatar
Thats cracking,very tidy!
Old 18-06-2006, 04:51 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
you pair of bastards
still, im working from a bare shell, colins car was already running and hes loaded
stil fair play to you both, cant wait for the results
i take it you decided not to chop the bulkhead and gone for a water rail instead then? or did you still need to chop it?
Old 18-06-2006, 05:06 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Looks smart that
Old 18-06-2006, 06:28 PM
Garage19
Garage19's Avatar
We were making a remote thermostat, but time is tight so Col just bought a raceline water rail. 48 days til ford fair.
I'm looking forward to seeing the results too. Hopefully they will make good reading
Just packed your squirters up. Can you PM me the address you want them sent to again. Ta.
Old 18-06-2006, 06:42 PM
R4N SS
R4N SS's Avatar
that looks mad
Old 18-06-2006, 08:35 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
so is chopping the bulk head and using the std one not an option then?
them water rails are loads of £££
pm sent my man
Quick Reply: The ZT is nearly finished (Ha ha - Mr Fudge)
