Gearbox oil recommendation
27-04-2006, 05:49 PM
Moderator
Just about to pop down to halfords for some gearbox oil.
Could someone tell me the best oil to get i know it needs to be fully synthetic
cheers,
Mark
27-04-2006, 05:51 PM
Some of the Honda boys use Land rover gearbox oil, sopposed to be good and cheap, the honda box takes a good old hammering to reving to 9000rpm
27-04-2006, 05:52 PM
Moderator
It doesent have to be cheap i just want the correct oil
27-04-2006, 05:53 PM
Not sure then but thats what i have been recomended for my honda which will be circa 300bhp through the standard box
27-04-2006, 05:58 PM
Moderator
Cheers for the advice m8.
Anybody else???? please!!!! I really need to get my car back together and down to halfords before they close
27-04-2006, 06:01 PM
infront of the gearbox oil will be a small black and silver flipcars thing.
flip this over to the page your car is on, and look at the part number next to the car model.
then select the gearbox oil with the same part number on it
27-04-2006, 06:03 PM
Moderator
as simple as that Jimbo!!?????
27-04-2006, 06:08 PM
Moderator
Crappy Halfords dont have any, does anyone know if i could get some in a petrol station?
27-04-2006, 06:27 PM
Moderator
27-04-2006, 06:44 PM
Autodata cd says:
2wd use ATF fluid
4wd use DEXRON II
27-04-2006, 06:46 PM
justa bout to put new box in mine too(2wd)
is there a "performance" gear oil that deals better with thre heat etc??
27-04-2006, 06:49 PM
27-04-2006, 06:51 PM
ive just got some atf fluid to change my oil ....ive always used it never had any probs i just change it every year with the diff oil
27-04-2006, 07:01 PM
Moderator
can i get this oil at a petrol station?
27-04-2006, 07:03 PM
Yip ATF (Automatic transmission fluid)
27-04-2006, 07:05 PM
27-04-2006, 07:07 PM
Moderator
is that fully synthetic lawnsy?
27-04-2006, 07:10 PM
not sure should say on bottle but autodata says use atf fluid
27-04-2006, 07:19 PM
dont put ATF in ffs
i'm sure i remember bernie saying it was a REALLY fookin bad idea
27-04-2006, 07:25 PM
RS & ST Parts Specialists
for 2wd use Castrol TDQ Dexron III
I can help if you need this oil
Matt
Moderator
From what ive been told Jim, Bernie actually reccomends it.
Ok i am now the proud owner of a 500mlbottle of Castrol automatic
TQ dexron III
Now, i dont actually want to do a full oil change if i dont have to, what happened was that i jacked the car up drivers side and pulled out the speedo cable, i lost about 1/4 - 1/2 litre of oil and i just want to top it up, i have no idea what oil is in there at the moment.
can i just use this ATF as a top up oil.
Cheers,
Mark
27-04-2006, 07:30 PM
Moderator
Matt
mines TQ not TDQ?
27-04-2006, 07:56 PM
Moderator
BTTT just need advice as to whether i can use this oil to top up whats already in my box then i can go and do it!!!!!!
27-04-2006, 08:16 PM
not really as you do not know what oil is in and some oils do not mix they just sit on top of each other like oil&water...in my opinion your best of dropping the oil and put fresh in
Topjoe9
12-09-2015 09:50 AM
fordfiestamk3
11-09-2015 12:52 PM
Adam Graham
06-09-2015 06:04 AM
gingeRS
04-09-2015 06:29 PM
CrOwSoN15
14
03-09-2015 12:21 PM
