NEED advice - Re Engine just been rebuilt.
Ok here is the situation. A friend of mine has just built his cossie engine (4x4 saph) back up from all new parts. He took a week off (he works for Ford) but is having a few setting up issues.
The car starts and idles perfectly but soon as he tried to drive it, it hesitates and lacks any form of power. it sort of coughts and splutteres.
His had roughtly from what i can remember
.5 oversized mahle pistons
whole bottom end rebuilt, crank etc.
T34 Hybrid turbo
RS 500 pace intercooler, Pace Rad and Pace turbo cooler.
Full Samcos
Oil seperator
Grp A fuel pump
3bar
new alcon 6 paddle clutch.
NGK brc8es plugs (just while his running in)
standard 4x4 cossie injectors (blue? again just for running in)
We cant find any air leaks.
anyone got any suggestions on what to check first? he doesnt really want to spend any more money if he can help it as its already cost well over £4.5K already (thats with him doing the work himself).
My cossie acted a bit like this and it was down to fueling? and his is behaving the same way. but what to do?
sorry if this sounds stupid but any suggestions/ideas i can get him to check would be great
cheers
Paul
T34 Hybrid turbo
Full Samcos
Oil seperator
Grp A fuel pump
3bar
cheers
Paul
Originally Posted by Billabong
What chip is he using for running in, and is he using the 3 bar MAP sensor with the std Blue injectors?
Originally Posted by BlackRSTFife
tell him to borrow one of the field engineers from regional office at a push drag the car to work and get em out lol
honest m8 its a customer car
not sure that will work
Originally Posted by abdr500
it sounds like the tps or connection to it allso cheack the map sensor if it isnt one of them the it will most likly be tdc sensor or timmimg is out
if your accellerate gently, soon as it hits 1/2 bar of boost it totally pops and bangs
he has made it run a bit richer and that has helped very slightly but still running like a dog
Originally Posted by SPADGE
If he has anything other than a stage 1 or standard chip with those injectors then thats his problem!
he had the standard chip, injectors and the t34 before the cambelt let go and it ran perfectly?
so could it be the fact his put the 3bar map sensor on the car with the standard chip and injectors?
If he put a 2bar back on while his running it in should that solve it?
once his run it in he was going to get a chip, and injectors and fit the 3bar.
Originally Posted by Speedy G.
If he has a chip for the 2bar, then yes, that's your problem.
thanks people
That's what I was getting at, but have been busy so only just seen the replies.
Yay it runs it was the 3bar, put the 2bar on.....runs perfect. now just need to order a chip and injectors, once it's run in his aiming for around 380-400hp
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
