Can i check if my car is low comp with a compression tester?
Old 05-04-2006 | 08:05 PM
lawnsy's Avatar
lawnsy
Default Can i check if my car is low comp with a compression tester?
as above.......
Old 05-04-2006 | 08:11 PM
EIL132's Avatar
EIL132
No
Old 05-04-2006 | 08:13 PM
Damo V's Avatar
Damo V
no
Old 05-04-2006 | 08:14 PM
lawnsy's Avatar
lawnsy
Old 05-04-2006 | 08:18 PM
chewy's Avatar
chewy
Would the next best way not be to use a burette with or something with an SG as close to water as possible ? I don't know and i'm enquiring as well
Old 05-04-2006 | 08:21 PM
Damo V's Avatar
Damo V
Yeah but head needs to come off really, otherwise you will loose the liquid down the side of the rims into the sump!!!, with the head off you can seal them with grease
Old 05-04-2006 | 08:22 PM
chewy's Avatar
chewy
of course
and if the head was off ideally use a piece of perspex / glass to cover the bore and then gradually add said liquid via a small hole ?
Old 05-04-2006 | 08:23 PM
Damo V's Avatar
Damo V
You have done your research
Old 05-04-2006 | 08:24 PM
Billabong's Avatar
Billabong
https://passionford.com/forum/viewtopic.php?t=119441
HTH
Bill
lawnsy's Avatar
lawnsy
mmmmmmmm think ill just have to take his word for it
Old 05-04-2006 | 08:26 PM
lawnsy's Avatar
lawnsy
won't let me read the link
Old 05-04-2006 | 08:29 PM
EIL132's Avatar
EIL132
http://mywebpages.comcast.net/mopauly/compression.htm
Damo V's Avatar
Damo V
Have to be a gold member
Damo V's Avatar
Damo V
Old 05-04-2006 | 08:46 PM
lawnsy's Avatar
lawnsy
CHEERS EIL132 don't think ill be doing it though a bit to much mess on i going to try and catch the old man who built the engine and question him ........see what he says
Old 05-04-2006 | 08:47 PM
Billabong's Avatar
Billabong
Sorry, didn't realise you weren't a gold member, but Eil has posted the relevant info
Old 05-04-2006 | 11:48 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Why not try this !!
Ensure a cylinder is on BDC after power stroke (ie both valves closed)
Measure accurately fluid entered into cylinder through plug hole
Then put another cylinder on TDC (compression stroke) both valves shut
Again fill up accurately with measured fluid
This will give you sufficient figures to work out CR without stripping what is a perfectly good running engine
Never tried this but the theory should work !
Old 05-04-2006 | 11:54 PM
rapidcossie's Avatar
rapidcossie
can you not ask for a reciept for the pistons used?
Old 06-04-2006 | 09:09 AM
RS2000CUSTOM
Doesnt help if head has been skimmed though
Old 06-04-2006 | 07:22 PM
Damo V's Avatar
Damo V
nor the fact all head chambers vary in size, plus the fact pistons are machined to create the desired CR (usually)
Damo V's Avatar
Damo V
Why not try this !!
But the liquid will probably pass by the rings.??..
kosienutter
31
22-08-2015 10:55 AM
taylora1409
12-08-2015 01:06 PM
Zoggon
10-08-2015 11:39 AM
MadsBL
Wheels and Tyres
06-08-2015 11:04 AM
CabrioTurbo
01-08-2015 12:04 PM
