engine stripped DAMAGE FOUND
Old Feb 18, 2006 | 02:10 PM
Default engine stripped DAMAGE FOUND
Despite the devastation to the Block the crank is fine with no damage.
One end bearing had started to spin the others were Ok. The block was held together by the crank bearing bolts.
Now have to decide on new or used 200 block, any ideas & the engine will be re-built with a couple of small mods that Mark wants to try as a development idea. Slightly different new pistons will be fitted.
Rod
Old Feb 18, 2006 | 02:12 PM
Alloy's Avatar
Alloy
Great new's that your not giving up Rod mate.
Here's hoping for a 210 plus run.
RANJ's Avatar
RANJ
well the blocks truely shafted ebay that
Old Feb 18, 2006 | 02:14 PM
Kev.H's Avatar
Kev.H
Default Re: engine stripped DAMAGE FOUND
glad your rebuilding and not giving up good luck
Old Feb 18, 2006 | 02:15 PM
R4N SS's Avatar
R4N SS
bigger and better Rod.
Begsy passenger ride when its back
Spax's Avatar
Spax
Good Luck Rod
Old Feb 18, 2006 | 02:18 PM
Hardeep_Singh's Avatar
Hardeep_Singh
very luck the crank wasnt damaged by the look of it!
Rhys's Avatar
Rhys
Fook that looks bad! For my untrained eye i would have thought it would have taken everything.
Rod you want to ebay your block saying its out of the worlds fastest Cosworth and you might get some £ back for it
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Thats looks well and truely battered!
Glad your not giving up, Hope all goes well in the future
Old Feb 18, 2006 | 02:19 PM
Dan's Avatar
Dan
Thats not a bad idea!
Glad to hear the development is continuing, best of luck Rod!
Gav Diamond's Avatar
Gav Diamond
Lucky that it never shafted the crank
Glad to hear you are rebuilding it mate
Old Feb 18, 2006 | 02:20 PM
KSA-Cossie's Avatar
KSA-Cossie
Youll be back bigger and better m8.
Old Feb 18, 2006 | 02:23 PM
Stu @ M Developments's Avatar
PassionFords Creator
Fookin Spiders... nice work
Old Feb 18, 2006 | 02:37 PM
Cam's Avatar
Cam
kin 'ell one destroyed block
Old Feb 18, 2006 | 02:45 PM
Jay,'s Avatar
Jay,
Sponsor
glad u aint give up rod
cheers jay
Old Feb 18, 2006 | 02:46 PM
gus's Avatar
gus
what about a millington block?
are these stronger/ better?
(i know nothing about them, jut that they are made with better water ways)
not sure if they are sutable for your use
Old Feb 18, 2006 | 02:47 PM
Charlie Chalk
Unknown.
Not designed for turbo use...
Old Feb 18, 2006 | 02:54 PM
gus's Avatar
gus
did mr hadland have one? old engine
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Glad you are going to rebuild it
Very lucky with the crank
Steve.
Old Feb 18, 2006 | 02:57 PM
James-W's Avatar
James-W
As said in other thread. Millington blocks are only rated to 400bhp and they have a habit of cracking under na power so putting 900bhp + through one isnt going to be advisable.
Looks like it could have been a lot worse than a new block Rod and Im glad your continuing the development I wish you the best of luck for the future.
Old Feb 18, 2006 | 03:04 PM
GARETH T's Avatar
GARETH T
thats one borken block
Old Feb 18, 2006 | 03:08 PM
RS500's Avatar
RS500
Maby next time a good idea to convert it dry sump.
A good starting point will be us zetec or svt engine block.
But if it has to be a ford cosworh engine you don't have to much choice maby a zetec cosworth wrc block will be ok if you can find one.
Or true frankenstein engine will be cool like a mitsubishi 4g63 or nissan sr20det or a toyota 3s-gte but that will piss of some people.
Old Feb 18, 2006 | 03:14 PM
dave cos4x4's Avatar
dave cos4x4
glad you are sticking with it Rod.
Old Feb 18, 2006 | 03:15 PM
rscostalot's Avatar
rscostalot
You fooked that rod...Good luck with the rebuild,JUST DO IT!!!!!!!!.............
Old Feb 18, 2006 | 03:53 PM
rapidcossie's Avatar
rapidcossie
bit of a mess that is!
sure mark will make stronger for the next time Rod!!
Old Feb 18, 2006 | 04:04 PM
pee vee's Avatar
pee vee
Would Any of them take 20k miles of hard abuse like rods?
doubt they would take any more.
fair play rod and mark, thats one broken block!
but good that you are going for it again!
Old Feb 18, 2006 | 04:07 PM
Staffi's Avatar
Staffi
That is some break, good luck with everthing Rod
Old Feb 18, 2006 | 04:10 PM
MikeR's Avatar
MikeR
Good luck with the re-build Rod, i am glad to see that you are carrying on,
Mike
Old Feb 18, 2006 | 04:19 PM
Fooking hell Rodney thats torn it If i can be be of any help to you Mark give me a shout as you know i was formally IMA Racing the best tuner bar none and built regular 1000bhp YB's
Old Feb 18, 2006 | 04:22 PM
89xr2's Avatar
89xr2
Brap!
Glad to hear you're not giving up.
Stick the fooked block on ebay stating it was first ever cosworth to do 200 etc might bring in some money for you.
Old Feb 18, 2006 | 04:26 PM
...and get those injectors sent
Old Feb 18, 2006 | 04:35 PM
Mark said someone wanted my 1000cc injectors, now ive found out who, the deals off .
Going to use 1200cc as Mark saw 100% duty cycle on that run trying to supply 900 horses with hay.
Anyone want an AUTRONICS SM2 ECU as Marks kicked that off the team as well. .
Rod
Old Feb 18, 2006 | 04:43 PM
Rhys's Avatar
Rhys
Why you not using SM2 Rod? and what u going for instead?
Old Feb 18, 2006 | 04:51 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
The new SM4 I expect Rhys
SM4 Mark wants more control of the Nitrous. can set a 199 'shot' instead of a '200' that caused all this aggro.
Old Feb 18, 2006 | 05:06 PM
Butch.'s Avatar
Butch.
you might be able to weld the bits back on the block
Old Feb 18, 2006 | 05:08 PM
Rod maybe you can give me that ECU cheap to get me fully MAD
Old Feb 18, 2006 | 05:10 PM
Apparently IMA Racing specialise in this, have sent for a price.
Old Feb 18, 2006 | 05:12 PM
£800 & its yours, control those 1000cc injectors better than what youve got.
