engine stripped DAMAGE FOUND
Old Feb 18, 2006 | 05:12 PM
  #41
Rhys's Avatar
Rhys
Originally Posted by MADRod
Originally Posted by Rhys
Why you not using SM2 Rod? and what u going for instead?
SM4 Mark wants more control of the Nitrous. can set a 199 'shot' instead of a '200' that caused all this aggro.
Ah cool i see Wish i could afford to buy your old one off you
Old Feb 18, 2006 | 05:23 PM
  #42
MAD matt-sab's Avatar
MAD matt-sab
shit thats looks bad but glad the crank etc are ok to run another day
glad to hear your not giving up either !!!!!
when u back at brunters ???
wont be long,your all MAD !!!!
Old Feb 18, 2006 | 06:01 PM
  #43
smitsturbo's Avatar
smitsturbo
is your saphire honestly putting out 900bhp or am i just gullible
why dont you get a specialist engineer to make 1 up from hardnd steel it might be expensive but so would buying new ones all the time, just an idea
Old Feb 18, 2006 | 06:14 PM
  #44
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
ebay it i reckon you'd get a fair bit for it
Old Feb 18, 2006 | 06:46 PM
  #45
Smit's Avatar
Smit
The 60ft Launch King
That's a bit broken Rodders
Glad you ain't giving up though, hope Marks new ideas help the new engine
Old Feb 18, 2006 | 07:06 PM
  #46
Mark Shead's Avatar
Mark Shead
quote="smitsturbo"]is your saphire honestly putting out 900bhp or am i just gullible
why dont you get a specialist engineer to make 1 up from hardnd steel it might be expensive but so would buying new ones all the time, just an idea [/quote]
We have no figs set in stone but you can work it out, 1000cc Injectors @3.5 bar +2.5bar boost so 6bar fuel pressure @8k 100% injector duty and we had to use the NOS fuel jets to add fuel I think it was 120 fuel jets which was double what we ran before.
So we can guess at 900hp and it is beliveable even for a scinic like me on HP est
Mark
Old Feb 18, 2006 | 07:20 PM
  #47
puddy's Avatar
puddy
Mark
Aaaaaaahh,the new MAD arse dyno!
Told you that nos push system would f*** your engine rod
Good luck with the new one
puddy
Old Feb 18, 2006 | 07:22 PM
  #48
Mark Shead's Avatar
Mark Shead
Mark
puddy [/quote]
Yes but you said it would be the pistons niping up not the main caps snapping
Mark
Old Feb 18, 2006 | 08:20 PM
  #49
JamesH's Avatar
JamesH
That is truely amazing Rod
And big respect for what you have already done, and if you can build it up again, and beat the record again, then that's just a bonus
I hope in the long run it is worth it for you to carry on with this
Old Feb 18, 2006 | 08:34 PM
  #50
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by jhw
As said in other thread. Millington blocks are only rated to 400bhp and they have a habit of cracking under na power so putting 900bhp + through one isnt going to be advisable.
Looks like it could have been a lot worse than a new block Rod and Im glad your continuing the development I wish you the best of luck for the future.
this millington block cracking issue is new to me also i know someone running over 700hp on one of these so being rated at 400hp may be a little conservative eh!!
Old Feb 18, 2006 | 09:18 PM
  #51
Alg1k's Avatar
Alg1k
Old Feb 18, 2006 | 09:20 PM
  #52
Martin-Hadland
Originally Posted by Alg1k
Also the crank
You say its ok
Double check it with a fine tooth combe
But then again i may be wrong !
i have already had that thought...
Old Feb 18, 2006 | 09:28 PM
  #53
Mark Shead's Avatar
Mark Shead
Sorry to here this Rod
Could this be the point at which the old cossy block is starting to flex quite a bit ?
I may be wrong though.
Its quite easy top stop the block cracking
Come on Rod your old school you should know
I have done it to my cyl block and i dont mean shotpeening and polishing the inside
Also the crank
You say its ok
None of the cracks started from any stress risers, I should know I looked at them first hand
Mark
Old Feb 18, 2006 | 09:41 PM
  #54
Alg1k's Avatar
Alg1k
Old Feb 18, 2006 | 09:44 PM
  #55
Mark Shead's Avatar
Mark Shead
Also the crank
You say its ok
There is no way on this earth that the crank is 100 % perfect and i for one would not reuse it in your engine running such torque induced by the Nitrous !
Thats you opinion its not mine and thats what counts
Mark
Old Feb 18, 2006 | 09:46 PM
  #56
Alg1k's Avatar
Alg1k
Old Feb 18, 2006 | 09:47 PM
  #57
Mark Shead's Avatar
Mark Shead
Also the crank
You say its ok
Mark
The block should have been dressed right not to have any stress risers
Engine Basics on a high power build
You cant see correctly what has been done and what has not
Mark
Old Feb 18, 2006 | 09:50 PM
  #58
Alg1k's Avatar
Alg1k
Old Feb 18, 2006 | 09:52 PM
  #59
Mark Shead's Avatar
Mark Shead
Also the crank
You say its ok
Mark
I suppose your right its Rods money after all
I suppose he will have to foot the bill when a sudden vibration turns into catastrofic failure
I just hope the flywheel stays where its suposed to
But then again im probably wrong
Yes your right you will be wrong
Mark
Old Feb 18, 2006 | 09:57 PM
  #60
Alg1k's Avatar
Alg1k
Old Feb 18, 2006 | 10:23 PM
  #61
Alg1k's Avatar
Alg1k
Good luck with the rebuild Rod
At least you have more that achieved your goals
It was enevitable that some thing was going to let go in the engine
with that amount of Nos on top of what you allready have.
It may be an omen !
I dont think anyone will get that kind of topspeed for a long while anyway.
Old Feb 18, 2006 | 10:29 PM
  #63
edd's Avatar
edd
dave they already did show em more than once how its done.
Old Feb 18, 2006 | 10:30 PM
  #64
leecavturbo's Avatar
leecavturbo
how many hours has it run @ 700bhp+ ?
2litre vauxhall methanol dragsters 1200bhp+ so i don't think the power wrecked the block!
why didn't you use methanol to achieve huge power ?
personally i think you/mark have pushed the boundry enough! and a credit to you both ,but it is risky business imo, you/mark want to be known for being the fastest not remembered for being the fastest if the worst was to ever happen. soppy old crap i know
Old Feb 18, 2006 | 10:31 PM
  #66
What i want to know is why on EARTH did you put the new NOS system on or what ever you was told to do ....your failure was listening to someone else and not sticking to your own abilitys IMO.
Old Feb 18, 2006 | 10:36 PM
  #68
edd's Avatar
edd
Originally Posted by YUM360
Yes but over 210
Old Feb 18, 2006 | 10:38 PM
  #69
The engine let go because it was pushed too hard because of the new NOS system...it found the limit of the YB and it was NOT a MAD idea...it blew because of outside influences...just keeping it real YUM.
  #70
edd's Avatar
edd
Donald Campbell?
Old Feb 18, 2006 | 11:32 PM
  #71
puddy's Avatar
puddy
Mark
puddy
Mark[/quote]
Maybe thats why you're changing the pistons as well
puddy
ps.time to go 4 x bolt mains !!!!!!!!!!!!
Old Feb 19, 2006 | 02:42 AM
  #72
bunjeeman's Avatar
bunjeeman
That's the spirit Rod, glad to hear that you will continue to carry the flame!!!
I can't wait for the day when I tell my buddies here in Hong Kong that there is an Cossie that can crack 210mph!!!
Old Feb 19, 2006 | 07:34 AM
  #73
Alg1k's Avatar
Alg1k
Old Feb 19, 2006 | 07:35 AM
  #74
Alg1k's Avatar
Alg1k
puddy[/quote]
puddy
ps.time to go 4 x bolt mains !!!!!!!!!!!![/quote]
Old Feb 19, 2006 | 08:35 AM
  #75
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Instead of taling in a cryptic fashion why dont you just say what you mean Phil. Anyone who has been keeping up with Rods progress knows what you are trying to imply: Chip has an input into the nos system and that why it blew is the message you are trying to get across isnt it which i think it bollocks. No way would Mark have anything on that engine that wasnt 100% ok.
Old Feb 19, 2006 | 09:04 AM
  #76
Old Feb 19, 2006 | 09:29 AM
  #77
BMEP's Avatar
BMEP
Rod,
Shame to see the engine come to such an end. Considering the extra stroke and 8,000rpm the piston speed would have been similar to a non stroke cossie revving to 9,000rpm let alone the massive Cyl pressure.
For the new engine it may be an idea to look into alloy con rods and an alloy flywheel to help reduce the rotating assembly/mass. At any given rpm, having a lighter rotating assembly will make life easier on the main caps/studs as the load on the main caps/block will be influenced by the rpm and the mass of the rotating assembly.
The only down fall for the alloy rods would be that they do have a “life expectancy” meaning that they would have to be changed every XXXXX miles of usage as well as the fact that you would have to compensate for “rod stretch” at high rpm's so inturn allow more clearance between the piston crown to Cyl head face.
Best of luck on the new build
Jake
Old Feb 19, 2006 | 09:55 AM
  #78
tracktoy's Avatar
tracktoy
proper fooked
good luck with the new build guys- its been said b4 but this is how we learn
Old Feb 19, 2006 | 09:56 AM
  #79
markk's Avatar
markk
i have to say fair play for fooking a YB block like no one else ever has true performance.
looks to me like it may ( and this is obv only from a few pics) have simply pushed the bottom of the block away with sheer piston force on the ignition(power) stroke, many ways to prevent this if thats what happened, couldnt be so sure without seeing it
this is what happens to development engines, im sure it was expected at some point guys.
  #80
AJC's Avatar
AJC
