Help please...cold start problem
I would like to diercet your attention to this thread
https://passionford.com/forum/ford-s...-required.html
Pay particular attention to the comments by Mr Mike Rainbird, that should put you at ease...or NOT!
I doubt it's anything serious like that as you would notice other symptoms the same as a blown HG such as losing coolant "Mayonnaise" etc, I had the very problem in that thread myself.
I would check the ignition system, leads, plugs etc and battery are in good condition, does it turn over as normal? A cold engine is much harder to start then a running temp one and so the electrical system needs to be in good order.
Martin
Martin
