Mk2 Zetec Modeo petrol. Bad smoke on cold start
Hi peeps,
I've got a Mk2 Mondeo Zetec petrol that has started to smoke really badly on cold starts. The smoke is white rather than blue, there is no loss of power, it starts first time and runs fine. I don't think that it's burning oil but to be honest I have not checked! The smoke normally disappears after a short while and as it is running fine I would be tempted to ignore the problem but it's belching out so much smoke it's embarrassing! When it's bad half the estate disappears!!!
Hoping that there is a cheap fix. Was wondering if it was a choke issue but seemingly there isn't one! Guessing it's not that then!
Any advise would be much appreciated.
As a rule white smoke/steam is typically headgasket related. If it was burning oil it would be blue and would be something like valve stem seals but i've seen even really tired zetecs to be smoke free.
If its white and producing that much on startup i would have a guess at it maybe being something like its leaking water into the cylinders and its burning off but you should notice it using water.
Are you sure it isn't just because the weather has taken a turn for the worse and its not moisture burning off in the exhaust? my AMG has been doing it the past few days on startup.... although more like a kettle boiling than a smokescreen.....
Is there anyway to adjust the cold start mix? Understand that there isn't a choke but is there a way to set limits on how much air is added on cold start? Could it be that it's not adjusting the mixture correctly? Still hoping of a cheap fix lol.
My first thoughts were condensation like any car but you described it as you couldn't see the street!
It does have a stainless exhaust on it so does have a larger tail pipe so guess it could get more moisture in it which burns off but it does have a strong smell to it!
A friend said it might be worth chucking some injector cleaner in it, change the oil that kind of thing. Might try and get some of that Stop Smoke to see if it's man enough to do the job?! Guess they can't hurt.
My st24 has a full stainless but only has mild condensation. The stop smoke products will only mask a problem.
Best thing you can spend on it is to get it to a garage for them to sniff test it at least. If its the headgasket as i described earlier it will be worse until the thermostat opens as the water will only be in the engine and not round the rest of the system.
I wouldn't keep running it though until you can rule out or confirm its the headgasket.
Theres still all the basic signs to look for, water loss, mayonnaise in the breather cap etc..
Cars! Gotta luv em lol
Need to know if it's oil smoke or water vapour, you should be losing one or the other!
Don't waste money on miracle cures in a can, stop smoke, all that crap.
Engine is electronically controlled, there's nothing to adjust.
JoeyBoyden
04-01-2024 02:36 PM
Archiejay
12-08-2015 12:07 PM
CabrioTurbo
01-08-2015 11:04 AM
