Remove Modeo gearbox
Old Nov 8, 2011 | 02:10 PM
revlo321's Avatar
revlo321
Default Remove Modeo gearbox
Hi fella's
Old fart needs help!
I have a 2002 mondeo estate with 1800 duratec engine.
Nothing on the body but think it's a basic 'L'.
No idea if it's Mk 1 2 or 3.
Gearbox is shot, the diff is crunching and lurching so need to change the box.
It's a 5 speed manual.
I have access to a ramp so will do it myself with the help of a mate.
Can anyone run me through the sequence and also the pitfalls to look for.
Regards to all.
Last edited by revlo321; Nov 8, 2011 at 02:27 PM. Reason: forgot to say manual, it's a duratec not magnatec
Old Nov 8, 2011 | 02:44 PM
RS 5tu's Avatar
RS 5tu
As a general procedure (mondeo shouldnt be too different):
Remove the battery (just to be safe)
Then remove the drive shafts, probably have to remove the lower ball joint to pop them out. also its best to undo the drive shaft bolts while the car is on the ground.
then remove the gear linkage and starter
then you want to remove any cables clips or wires attached to the box (take a close look as if you miss one you could brake it once lowering the box out)
not forgetting the clutch cable or slave cylinder depending on what you have.
now you want to remove the mount(s) or it may have a cradle (ive not done one on a mondeo)
now you want to start taking out the bell housing bolts (i tend to leave the 2 top ones in till last as you dont want it dropping while your under the car)
once you have done all that check there is nothing else bolted on, AC, PAS pipes ect
then it should be ready to come out if you using a ramp ideally you will have something to rest the box on if not you could always do the final part on the ground with a trolly jack.
Just to give you a idea of where to start.
Old Nov 8, 2011 | 02:51 PM
RS 5tu's Avatar
RS 5tu
take a read of this:
https://passionford.com/forum/genera...ml#post5643265
Old Nov 8, 2011 | 03:47 PM
dojj's Avatar
dojj
Resident Wrestling Legend
everything is bolted to the cradle, if you don't remove that, nothing comes out
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
grishenko45
Sep 9, 2015 12:58 PM
gingeRS
Sep 4, 2015 06:29 PM
hopper350
Sep 4, 2015 12:53 AM
