St170 rough on start up
Old Sep 1, 2014 | 03:24 PM
James1290's Avatar
James1290
Default St170 rough on start up
Hi everyone,
I'm getting a bit worries as when I start my st170 up it sounds a little rough (this does not happen all the time) it's like a grinding/clicking noise. It doesn't sound like it's misfiring and drives fine, power seems ok.
Need some advice please?
Old Sep 1, 2014 | 03:40 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
find out if it has a dual mass flywheel as standard
Old Sep 1, 2014 | 03:50 PM
James1290's Avatar
James1290
Could it be the IMRC??!
Old Sep 1, 2014 | 03:54 PM
RichieST's Avatar
RichieST
Any lights on the dash?
Old Sep 1, 2014 | 03:57 PM
James1290's Avatar
James1290
Yes it has. Had the clutch and a new dmf fitted a few months back
Old Sep 1, 2014 | 04:02 PM
James1290's Avatar
James1290
Nothing on the dash either?! ��
Old Sep 1, 2014 | 04:04 PM
RichieST's Avatar
RichieST
If when you start it up and it makes a series of clicks, think there was about 8 or so then stops, then it's the IMRC. Silver box bolted to the bulkhead behind the exhaust manifold. Unplug it and if it stops then you've found your problem.
Old Sep 1, 2014 | 04:10 PM
James1290's Avatar
James1290
Yep that definitely sounds like the problem as you said it stops after around 8 clicks. Is this expensive to get fixed/replaced?
Old Sep 1, 2014 | 05:17 PM
RichieST's Avatar
RichieST
It is straight forward enough to do yourself, not sure about price of the part though. Only thing I would be worried about is it should have bought the engine management light on. Make sure that the light comes on with the ignition, then goes out shortly after startup. If it doesn't, someone has taken the bulb out!
Old Sep 3, 2014 | 11:14 AM
hydro st170's Avatar
hydro st170
Hi I was having same prob and I thought it was the imrc box but I then found it was the nipple on the dsi clip had broke of.So I went to ford and they wanted to sell me a new manifold but after a bit of arguing and checking he found the part number and got it ordered.I only found out after that u can get a metal 1 that would have been better. I got the old 1 of no prob but I don't seem to be able to get the new 1 on with the spring.I dont want to pay ford the money to put it on can any 1 tell me is there a certain way to put it on .Thanks
Old Sep 5, 2014 | 04:01 PM
James1290's Avatar
James1290
Ok thanks for the responses I'll have a look at both possibilities.
Kyle Langford
27
Aug 5, 2019 07:54 PM
Rsmat
63
Sep 25, 2015 12:11 PM
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
track.focus'd
Aug 12, 2015 05:53 PM
