82 degree thermostat for rst *update* Needs modification
Old 13-04-2005, 06:58 PM
CasperR
CasperR's Avatar
Default 82 degree thermostat for rst *update* Needs modification
Hi
As topic says. I ordered up a 82 degree sierra thermostat and a cossie 4x4 fan switch. The fan switch was a perfect fit but the thermostat didn't fit at all. so someone has got their information wrong
Used the numbers from this post..
https://passionford.com/forum/viewtopic.php?t=111712
Pics to follow..
Comparison of the original rst thermostat and the "supposedly" 82 sierra item
Old 13-04-2005, 07:06 PM
glenis
glenis's Avatar
Shit !
i will have the same problem then !
i have fitted my fan switch, and was going to fit the thermostat soon !
i will have to take mine back...!
ON-UJAH please help us !!
Old 13-04-2005, 08:14 PM
ON-UJAH
ON-UJAH's Avatar
DONT PANIC!
Right, take a look at the stat - you'll se on the flat edge, a line. Cut along this line, all the way around. You'll remove about 2mm from the diameter of the stat, without affecting it in any other way at all. It will now fit into the housing. A Ford gasket ring is quite thick so you may have trouble gettign the clip in. You can either find a thinner rubber ring, or use gasket sealant suitable for such a job - Loctite Gasket number 2 is what I used.
Edit - just noticed from the pics, that the line is quite clearly visible. Due to the nature of the clip, you dont have to follow the line exactly round, just thats about where you need to cut. It takes about 3 minutes with a Dremel wheel.
Also, it certainly is an 82 deg. stat - take a close look it should have it stamped on it.
Old 13-04-2005, 08:19 PM
glenis
glenis's Avatar
nice one ....
saved the day again!
your the man, cheers !
Old 13-04-2005, 08:22 PM
ON-UJAH
ON-UJAH's Avatar
Phew!
Old 13-04-2005, 09:01 PM
CasperR
CasperR's Avatar
But why wasn't this mentioned in the other post?
I'll change the topic, but it still seems weird that you have to mod the thermostat.
Would you need to mod the xr2 one aswell?
Old 13-04-2005, 09:04 PM
glenis
glenis's Avatar
can it be cut with tin snips ?
Old 14-04-2005, 08:58 AM
ON-UJAH
ON-UJAH's Avatar
Your best off using a dremel really, I dont think tin snips would be very easy. I used a cutting wheel, then a stone to clean up the edges. It's a pain to get the clip in securely, you have to use the stone to grind it down a little until the clip fits in its groove nicely, and a bit of muscle with a big screwdriver to push the clip in.
A XR2i one will fit straight in, as it's also for a CVH. It is in fact the exact same part number as the one for ERST. TBH I just ordered through a mate at Ford the 82deg Sierra item (it was the only one in the Ford catalog with 82deg that I could find), and when it arrived cut it down and stuck it in. It's not a hard job at all really. Just takes a bit of patience and a good dremel.
Why nobody mentioned the modding - well I just saw it as another bit of fun to do after work, I mod practically every part that I get to try to make it better in some way (more often than not it involves the Dremel ) - but I'm like that I guess....I prefer to spend thousands building a ZVH, instead of just buying an old Audi Turbo.
Old 14-04-2005, 09:02 AM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Why do you all mess around cutting these? I can supply an 82° Stat that will fit straight in, as I said before.
Old 14-04-2005, 09:10 AM
JesseT
JesseT's Avatar
Get a 82degree Toyota MR2 thermostat from your local spare parts store. It's a straight fit and cost a fiver over here.
Old 14-04-2005, 09:14 AM
ON-UJAH
ON-UJAH's Avatar
You'll have to shout louder mate! I didn't realise that.
But us Europeans, we generally have to rely on Ford - you don't realise just how hard it is on the mainland, there is a completely different attitude to cars and modding here. I'm sure if you knew the part number, you could go to Merc, Audi, Scania or wherever and get the part that will fit - it's finding that number that is impossible. People on the parts desk have no idea and are not willing to help - an autoparts shop is even worse. They will generally throw a 1000 page catalog in front of you and tell you to find them the number People in the know are very thin on the ground, and tend to remain silent. I myself can only get Ford part numbers, by looking through the catalog, and am happy to post them up if someone asks...
Necessity is the mother of invention, it's all part of the fun IMHO.
Old 14-04-2005, 09:20 AM
sufsRS
sufsRS's Avatar
has evry1 gone deaf forget evryfing no xr2i thermostats no modding and specially nt mr2 thermostats
Old 14-04-2005, 09:58 AM
adamS2RST
adamS2RST's Avatar
Exactly what I did, got one from Christian, straight in
Old 14-04-2005, 01:46 PM
glenis
glenis's Avatar
just walk into halfords and buy a thermostat for a FORD PUMA 1.7
i did this today, and it fitted straight in... its STAMPED with 82 degress...
just the job, and i even swapped the boxes over, so i paid for a RST stat (Ł4.49) and got the gaskets, clip and ring...
and now it runs just below NORM
Old 14-04-2005, 01:51 PM
sufsRS
sufsRS's Avatar
if u bought off mr c it would save u a trip 2 halfords u swapped the boxes round isnt that just the same as theft? and sum 1 else is gna get the wrong thermostat right?
Old 14-04-2005, 01:55 PM
glenis
glenis's Avatar
2 trips to halfords is quicker than waiting for something to come from norwich, via postman pat...
and i dont know who took 2 trips...
no one nicked it, paid and got a reciept, same price.
Sorry Officer
Old 14-04-2005, 01:57 PM
sufsRS
sufsRS's Avatar
just duin my duty so the point of swappin the box ova was wot?
Old 14-04-2005, 02:39 PM
ON-UJAH
ON-UJAH's Avatar
Wish I'd known that could have saved some trouble. Unfortunately most of the stats listed in the Ford catalog are without the temperature. The only one I found which had 82deg listed was the Sierra item pictured above, which other people have spoken about on the forum.
Here's the FINIS for the Puma stat, it is the only one I have listed for the Puma:
1007754
So, thanks to Glensis, it looks like this cat is now dead and buried.
Old 14-04-2005, 03:57 PM
Christian and Beccy
#1 in Spelling Club
Until Ford change the supplier and the design becomes slightly different.
I can do one that WILL fit for a tenner inc Postage. Why take the risk??
Old 14-04-2005, 04:30 PM
CasperR
CasperR's Avatar
Got it sorted today. Got the dremel out and made it fit. Car now runs alot cooler that before and its all good
Christian and Beccy: sorry I should have asked you
Old 14-04-2005, 05:44 PM
glenis
glenis's Avatar
no worries mate... you got the fan switch correct... that helps and is 50% of the problem...
no we all know which stat to buy, a puma one. simple.
Old 14-04-2005, 07:55 PM
cooler king
cooler king's Avatar
a puma one?????? hmmmm, i shall pull it apart to see if its the same size he he he!!!!!!!
if not i think its an apt one for me!!!! still need to get the switch ordered!!!!
cooler king
Old 14-04-2005, 11:06 PM
BillyCabrio
BillyCabrio's Avatar
Location: Dartford, Kent - Home of the two way one way system.
Better add that to my Mr C shopping list.
Old 14-04-2005, 11:28 PM
G420 DEL
G420 DEL's Avatar
out of interest what does the cossie fan switch do that diff to the RST switch?
Old 15-04-2005, 05:17 AM
cooler king
from what i can gather it cuts in earlyer than the rst one!!!!! at 82 degrees instead of 88??????
Old 15-04-2005, 07:28 AM
ON-UJAH
ON-UJAH's Avatar
Cuts in at 86deg, out again a few degrees below that.
Standard one is more than 88...it should be stamped on it but iirc it is in the 90's
Basically you're just increasing the time it takes before temperatures get critical. It's no solution to an overheating problem - for that you need a good radiator (GRS or similarwith a really efficient core) and a good fan or two to get cold air through it while sitting at the lights. A really good radiator isn't that expensive either.
Old 15-04-2005, 06:10 PM
G420 DEL
G420 DEL's Avatar
think u misuderstood me i know what the thermerstat does that is plainly obvious
i asked what the cossie fan switch did different to the RS fan switch
Old 15-04-2005, 06:38 PM
glenis
glenis's Avatar
cuts in at a lower temperature, as in switches the fan on earlier or sooner
Old 15-04-2005, 07:03 PM
addiction
addiction's Avatar
why dont you all just buy an 82 degree thermostat for the rst from burton power? only Ł7.93
Old 15-04-2005, 08:31 PM
glenis
glenis's Avatar
Ł4.49 just down the road
Old 15-04-2005, 09:18 PM
G420 DEL
G420 DEL's Avatar
cheers mate
Old 15-04-2005, 09:55 PM
Christian and Beccy
#1 in Spelling Club
Plus postage??
Mine is a tenner posted.
Old 16-04-2005, 10:53 AM
sufsRS
sufsRS's Avatar
probly not maybe another tenner!!!
Old 16-04-2005, 11:36 AM
ON-UJAH
ON-UJAH's Avatar
I didnt missunderstand you - it cuts in (turns the fan on) at 86deg. It will be stamped on the side with this figure. As it cools the engine, it cuts out again at about 82 degrees. A combination of the 2 parts will try to keep the engine between 82 and 86 degrees.
If you got connections at Ford, the stats cost about 4 quid. And for about 20p you can get a new fibre washer for your new switch - 6005731.
glenis
glenis's Avatar
Old 16-04-2005, 11:37 AM
glenis
glenis's Avatar
knew i'd missed something
lol
Old 16-04-2005, 02:14 PM
cooler king
but do the ones from ford that you got fit straight on or are thwy the ones you have to cut down?
Old 16-04-2005, 02:18 PM
glenis
glenis's Avatar
your getting confused cooler king, all ford ones will fit...
just make sure you get the right one, PUMA 1.7 will do it, straight in
Old 16-04-2005, 03:50 PM
cooler king
doh, its not hard!!!! what i meant was, i want onre that doesnt need cutting down, so the puma 1.7 one is the one i need for this then?
Quick Reply: 82 degree thermostat for rst *update* Needs modification
