big power cvh problems with roller rockers pics
Old 26-07-2011, 08:21 PM
  #81
Rob_DOHC
Rob_DOHC's Avatar
lol, cheers for the sympathy fella I hope its the only damage too mate, i think it will be the rocker still looks in one piece and the compression test was good..... yet another oil change when its repaired i guess....
Sorry to do a thread steal Stuart!
But, how do people normally set about repairing the above? literally drill out thread, helicoil and a new stud? should a be a good boy and take the head off to do it
Rob,
Old 26-07-2011, 10:15 PM
  #82
Karlos G
Balls Deep!
Karlos G's Avatar
Nightmare Rob!!
I just used an ebay helicoil kit when i had it happen before.
Old 26-07-2011, 11:27 PM
  #83
Rob_DOHC
Rob_DOHC's Avatar
I know mate, was driving so nicely too, never ending!
How did you repair yours mate? Every things fresh so i don't really want to remove the head, did you do yours with the head fitted?
Rob,
Old 27-07-2011, 12:27 AM
  #84
Raj_FRST
Half Rice Half Chips
Raj_FRST's Avatar
Great info jano !!! cheers
rob a new design would be the only option imo, how mad is that about your car??? spooky mate
Old 27-07-2011, 12:48 AM
  #85
Joshy
Dreamer
Joshy's Avatar
Originally Posted by Rogeyboy
Joshy - R u sure? I thought they were pressed in? I'll have a play with a spare head i have...
yep, at least they were on the RST head i refurbed, was a 89 head i think..
Old 27-07-2011, 08:58 AM
  #86
Rob_DOHC
Rob_DOHC's Avatar
Good stuff, so long as you test the stuff properly and take a logical approach to the design you should be fine.
I know! i'm yet to take the rocker cover off and have look
Rob,
Old 27-07-2011, 12:42 PM
  #87
nigel b
nigel b's Avatar
Gutted for you rob
Easiest repair would be a helicoil or wire Inserr,be careful as the sizes are slightly different with drillng/tapping
The insert to use would be a spiralock,only downside is you will not be able to take the stud out again!
Or something we use in the aerospace industry
Rosan inserts
We use these in the damper housing for landing legs,every commercial aircraft has one of these fitted
Downside is it would he a time consuming job to machine and install as the locking ring needs pressing in
Old 27-07-2011, 01:00 PM
  #88
DazC
DazC's Avatar
I've helicoiled them in the past with no detriment. Just the usual off the shelf helicoil.
I still can't understand why people manage to snap rockers. Studs pulling out I can half understand as they are always under tension and the soft ally head can weaken but I can't understand how the rockers actually break.
Old 27-07-2011, 02:15 PM
  #89
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Like this
Old 27-07-2011, 03:50 PM
  #90
stuart collins
stuart collins's Avatar
cos they are old and shit
Old 27-07-2011, 04:42 PM
  #91
rstdave
rstdave's Avatar
I'd have got fucked right off a long time ago if i was you mate and scrapped the cvh idea, mine used to break things often enough with less bhp than yours lol!
As much as i love the cvh engine in an rst as it's inkeeping with the car imo over a zetec/zvh, getting big power builds to stay together isn't easy....if i was gonna go for 300+ it'd have to be a zetec now!
Old 27-07-2011, 04:52 PM
  #92
Karlos G
Balls Deep!
Karlos G's Avatar
Rob,
I didnt do it with the head fitted but if you take the cam out and are extremely thorough with removing the swarf after drilling/tapping you could do it in situ maybe?! But it does make a right mess.
Old 27-07-2011, 06:13 PM
  #93
gus
gus's Avatar
for the extra hassle of taking the head off i would rather do it
swarf just gets everywhere
Old 27-07-2011, 06:16 PM
  #94
Rob_DOHC
Rob_DOHC's Avatar
Cheers for the reply s guys,
Nigel those inserts do look very tasty!, Karlos, when i've got the rocker cover off and seen what damage its caused i'll take a view on whether to do it fitted or not realistically i'd like to do them all which i wouldn't do with the head fitted.
Jano, that rocker looks as if its been battered! are you sure the stud didn't pull out and the rocker rattled around the cam gear until it was broken?
Weird resonance in the springs could cause the collet to dislodge and the valve to drop, maybe this broke the rocker at the same time?
Dazc did you helicoil with the head fitted?
Rob,
Old 27-07-2011, 06:18 PM
  #95
Rob_DOHC
Rob_DOHC's Avatar
I know im just talking my self into it gently... with a new bottom end nearly run in i think its worth the hassle of doing it properly...
Not the right time to be spending more money on the car either... new head gasket and studs
Rob,
Old 27-07-2011, 10:35 PM
  #96
DazC
DazC's Avatar
Rob,
Yes. A tip for you while drilling it out. Hoover!
Old 27-07-2011, 10:39 PM
  #97
nigel b
nigel b's Avatar
rob
dont even think about doing it in situ
you will never catch all the swarf and there will be very fine bits of swarf that will never get picked up
Old 28-07-2011, 08:55 AM
  #98
Versus_Creations
Ask me a question!
Rob the parts i have shown are from different engines. The studs had no issues on any of the engines.
Old 29-07-2011, 03:59 PM
  #99
Rob_DOHC
Rob_DOHC's Avatar
Lol, i did conceder this, and cutting the hoover extension to sit right under the hole.... but i've talked my self into doing it the hard way plus the ear ache i would get for 'modifying' the hoover lol
rob
Its taken a few days but thats what im going to do no point in spending this many hours blueprinting and building and pouring a cup of swarf into the sumpAny ideas on who stocks the rosan inserts? If im doing it i may as well do them all properly.
Jano, shit thats not good!
Rob,
Old 29-07-2011, 08:44 PM
  #100
Tommys1turbo
Tommy Turbo
Tommys1turbo's Avatar
To be fair I put this down to driver error.!
Old 04-08-2011, 07:35 AM
  #101
stuart collins
not just me tho is it gayboy , wat have u just broken????
Old 04-08-2011, 07:36 AM
  #102
stuart collins
roller rockers on there way with titanium valve caps
Old 04-08-2011, 08:05 AM
  #103
russ rs
russ rs's Avatar
Result mate
Old 04-08-2011, 08:54 AM
  #104
Rob_DOHC
Rob_DOHC's Avatar
Job jobbed, who did you get the rockers off?
Rob
Old 04-08-2011, 10:34 AM
  #105
nigel b
nigel b's Avatar
Stu
Hope you solve your problem
Rob
we get them from here
http://www.wescoair.com/Pages/VariationRoot.aspx
These were the other type of inserts I was thinking about
http://www.ezlok.com/InsertsMetal/index.html
Old 05-08-2011, 08:18 PM
  #106
Rob_DOHC
Rob_DOHC's Avatar
Thanks very much for the links Nigel, i've got all the bits to repair. doing it tomorrow.... cutting it a little fine for ford fair!
Rob,
Old 05-08-2011, 08:54 PM
  #107
Ben26
Ben26's Avatar
need to keep an eye on this thread, some very intresting opinions going on
Old 05-08-2011, 09:05 PM
  #108
Canada1
Canada1's Avatar
I would certainly look at using a Timecert insert for rocker arm stud threads.
We use these for 911 Porsche magnesium cases for the head studs - they pull out from the
soft magnesium. The timecert inserts work fantastic and don't pull out even on endurance 9000 rpm 2.0 liter Porsche race engines.
I would trust these inserts which are far superior to helicoils.
See the website:
http://www.timesert.com/
Old 29-09-2011, 07:53 AM
  #109
stuart collins
Old 29-09-2011, 08:26 AM
  #110
Mids_s2
Mids_s2's Avatar
Look spot on they do mate, just out of interest how much do they cost?
Cheers Ben
Old 29-09-2011, 10:35 AM
  #111
DazC
DazC's Avatar
Looking good Stuart! They cost a few quid didn't they if I remember correctly. Is there any plans in the pipe line to make some more?
Old 29-09-2011, 02:22 PM
  #112
stuart collins
jano is havin some made at around 600-700 then theres the price of the titainium valve caps on top of that, titain would make the rockers at 1500 for me then + the valve caps , these came of the mts mk3 n/a track are as they are goin complete zetec , it was revin to 8700rpm no problems
Old 29-09-2011, 06:27 PM
  #113
russ rs
russ rs's Avatar
awsome!
do I get ride with them in then???
Old 29-09-2011, 07:19 PM
  #114
jonny s2
jonny s2's Avatar
Have you not got it back together yet
Looking good pal, cant wait to hear your results to how they make it perform
Old 29-09-2011, 07:49 PM
  #115
russ rs
russ rs's Avatar
Is sat the day mate ?? I hoping be out
Old 29-09-2011, 08:09 PM
  #116
Canada1
Canada1's Avatar
Nice!!
Old 23-12-2019, 08:00 PM
  #117
1982 EXPert
1982 EXPert's Avatar
Originally Posted by Canada1
I have attached a picture.
This is the large hole in the head which oils the camshaft/lifter lobes.
As you can see there is no brass restrictor in the North American heads.
We have never had cam wear issues.
Attachment 136738
Canada1 CVHs in North America DO have cam wear issues, the journals rarely have problems but the lobes like to wear out on the flat-tappet cams. I believe it's the exhaust lobe for the 3rd cylinder that tends to wear out first and I don't know why.....
Maybe it's dependent on what cam and valve cover you have, my 1.6s seem to suffer lobe wear the hardest :/
Old 24-12-2019, 04:58 AM
  #118
haz87
haz87's Avatar
Holy thread revival!
Old 27-12-2019, 09:34 AM
  #119
Rsmat
300+
Rsmat's Avatar
I've been running a time certed head with roller rockers just over 300hp for over 3k mileage, I think times have moved on , what was you all fucking about at back then ::
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
nick8saff
16-08-2015 05:35 PM
track.focus'd
12-08-2015 05:53 PM
Blown Hell
05-08-2015 07:22 AM
Quick Reply: big power cvh problems with roller rockers pics
