Urgent help needed! Set up problems on dyno!!
Hello guys,
I'm despred for some help so please read this!
My car has been on the dyno quite a while ago putting out 181 bhp and 295 nm as you can see on the blue lines here
![](http://i216.photobucket.com/albums/cc145/dutchrsturbo/DynorunRSTurbo.jpg)
After the set up i changed my oilpump, because i thought to see that my oil pressure was a bit low (no oil light, but seen from a VDO meter)
Next oil pump same thing on the meter, but also it seemed that i had less power, so i thought that my timing changed by accident while the timing belt had been off.
To be sure about the oilpressure i orderd a new one which a recieved last week and so i went to the dyno yesterday.
1st run 151 bhp and 225 nm, so i thought yeah there is indeed power to gain and it wasn't just my thought that i was slower.
BUT here's the problem:
We just can't get a good set up on it! On high revs turbo pressure is dropping much more as it did during the first set up. Also the camshaft timing doesn't seem to change the peak in the powercurve, which i think is really strange
We have by passed the amal valve, but (with the much lower boost) it also seemed to drop on high revs
We have monitored the actuator pressure which seems to drop so the wategate should close op the moment that boost drops
We have measured inlet temps which seems to be fine
we have tried lots of camshaft settings with same timing, but the peak looks like it stays quite on the same place. I expecet much more movement in the power curve
Also lamba seems to be quite ok, not the problem i my view
I just can't get my head around what the problem can be!![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
We stopped at 5 o clock yesterday and we will continue on mondayevening, but i have no idea where to look for the problem
These where the first and the last run from yesterday
![](http://i216.photobucket.com/albums/cc145/dutchrsturbo/CCF03102010_00000.jpg)
Is my camshaft fucked? Are my electronics holding him back on ignition?
Engine spec is
1600 8v
Chipped ECU
Flowed head
285t camshaft
Turbo spec
TOB32
T03B as
360degr bearing
exhausthouse .48
inlethouse Z32 + compressorwheel
As you can imagine i'm still on the dyno with a big bill waiting for me and no results. I hope somebody can give me the right tip where to look for this problem or what to try on set up![Neutral](https://passionford.com/forum/images/smilies/icon_neutral.gif)
PLEASE HELP
Engine spec is
1600 8v
Chipped ECU
Flowed head
285t camshaft
Turbo spec
TOB32
T03B as
360degr bearing
exhausthouse .48
PLEASE HELP
![god](https://passionford.com/forum/images/smilies/dieu.gif)
i'm not holding boost, but it also looks like i'm missing lots of power on the lower revs
boostcontrol is by amal valve it's almost a std engine
You don't hear a leak from anywhere and also it's strange that it holds that peak everytime around the same revs. If it was a leak i would say that peak wouldn't be there
sounds like actuators weak and ive always thrown away the amal valve as they are crap and just fitted a bleed valve....
a mate of mine had a worn cam lobe and that made his lose power and if you had poor oil pressure it could be your problem mate also is it a rs specialist setting the car up as they would find the problem in 5 mins
actuator was brand new before the first set up..
So losing the amal valve is a option can't i connect it direct on the inlet part of the turbo?
It's not a rs specialist but we don't have any in the netherlands!
Also there has always been oil pressure but on my VDO with a 0 to 10 bar scale it was a difficult read out and i chose to put on a brand new one now
Balls Deep!
Nothing wrong with the amal valve, and it keeps a bit of safety if the ECU see's knock or high ACT's and can then shut the boost down.
Besides which this has nothing to do with your problem
lol
You may not hear a leak so pressure test the intake system to be sure.
Have you done a compression test?
It could be the ECU pulling timing back yes (again knock sensor, ACT sensor, or faulty ECU), put a timing light on it whilst doing a run and you will see.
i did a compression test a while ago and then it was good. Could it be a faulty knock sensor? Is it placed on all cvh's? i don't remember where it would be...
We took ATC with a fluke meter, so it's not a quick reading maybe going to do that again... it stayed on the fluke on 31 degrees maximum
i wouldn't know why my ECU would be fucked now. i have had a couple of wires which where bad, but i fixed that and that normaly would not fuck up my ECU
Is the rollers the same as the one you used when you first had it setup or have they changed at all, dont shoot me down here but could it not be a case of the first setup been abit healthy with the results and now the new rollers are giving you a more accurate result for your engine spec.
Just wouldnt a 180bhp car need a better spec? it doesnt have a uprated intercooler by the spec listed.
cheers adam
cheers adam
Balls Deep!
The ECU is 20+ years old you dont have to do anything it could just be faulty.
As I said above, pressure test the inlet system, and check the timing when doing a run, then go from there...
ow now i see that i forgot to say that i changed from a GRS IC on the first set up to a Airtec new one on this set up.
I went to a other tuner because of a lack of cooling by my first tuner. The tuner i have now has a superflow dyno, so no mess and also better cooling.
Besides a dyno change the powercurve should change much more when timing is changed and my boost needs to be hold more!
I'm going back tomorrow with a other ECU; Ignition and going to set the camshaft roughly to make sure we are close to what it needs to be. Also i'm going to check for leaks
A other point that i would like a answer from somebody does the amalvalve control change when you pull off the connector?
Balls Deep!
If you unplug the amal the boost should be lower yes.
Yeah it could cause a boost drop and i see that because my peak boost is 0,1 bar lower. I can solve that problem, but resistance can't increase in such a big way at higher revs in my opinion.
If i bypass my amal valve the boost is lower, but when i disconnect it nothing happens! Is my amal valve f*cked?
Just opent another thread to expand my knowledge about the system on the MFI
https://passionford.com/forum/ford-e...ml#post5118935
Think i can use that knowledge tonight!
So it would be better to fit a other amal valve then? I don't know his way of functioning. Is it that now my inlet en actuator are connected with a blowoff to the inlet by a spring and something that the ECU controlls?
Sorry but lots of this is difficult to understand for me because my english isn't that great
and if i pull of the connector from the amal valve it should close and let the actuator see the real pressure, but that doesn't work then?
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
