boosting problem
Old May 9, 2009 | 02:29 PM
Korda's Avatar
Korda
Default boosting problem
when i go to boost up it sounds like a air leak been cheaking all
the boost hoses all ok, what other parts need looking over thanks
Old May 9, 2009 | 03:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What does it actualy do, boost cut in and out? Not spool up at all? Overboosting? backfiring?
Old May 9, 2009 | 03:37 PM
Korda's Avatar
Korda
boosts but not well seems like powers down when it cuts in seems flat
Old May 9, 2009 | 04:53 PM
orionmojo's Avatar
orionmojo
if it makes loads of noise like its sucking loads of air but goes nowhere
check your dizzy.
Old May 9, 2009 | 08:35 PM
Korda's Avatar
Korda
sounds right sucking air but not boosting up that well
Old May 10, 2009 | 11:41 AM
orionmojo's Avatar
orionmojo
very first thing i'd do is to check your dizzy and timing.
Old May 10, 2009 | 11:43 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If your running standard boost then set it to 12degrees BTDC with the vacuum hose to the ECU blocked off on the inlet manifold.
If you've had it tuned and running high boost then back to the tuners mate or you risk your engine by guessing what it should be set at!
Old May 10, 2009 | 04:32 PM
Korda's Avatar
Korda
thanks i will take a look in a bit and let you no
Old May 10, 2009 | 05:44 PM
Korda's Avatar
Korda
had a look and the turbo has play up and down side to side, going to take it to a tuner tuesday.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
