Water Spray Intercooler
I have been playing in my garage and made this, don't suppose it will make the slightest difference but it stops me drinking beer for a while!
Got thes nozzles made
And fixed them into my bumper
Fitted another pump into the screen wash tank
And fitted a pressure switch to control it
It starts the pump at 7 psi
of course it will drop the intake temps but by how much no one no's,how efficient is your cooler??
try putting your hand out a car window at 50mph and then doing it with a wet hand !
p.s evos come with water spray.
I got the pressure switch from rs components. No screen wash in tank any more, would have liked a seperate tank but could't fit one easily so thought i would try this, if i cant clean my screen with water i will have to re-think.
Subaru's also have them, but i think it is quite accurate how you place them and how they spray. Try it with a tempsender in your charge carrier. The only way to find out if it does anything good
If your intercooler is crap then this is needed if you have a good intercooler then it is not needed i tried this on the pace interwarma 10 years ago and made fuck all different to it
Wrong!!!!!!!!!!!Youre talking about "windchill" which has NO affect on a intercooler.Spraying water on intercoolers was tested and the results reported on the Ford RS Owners site yrs ago.Done by a well known respected member,(could have been Steven RW,maybe???) anyhows the result was that it made no difference what so ever!!! Regards,Micky
I have a similar set up on my car if your happy then dont worry about the replies, just one thing if you have plumbed the pressure switch into the knock sensor hole did you drill it first as its not got a hole already so switch will not see any pressure?
PaulT
PaulT
I did this 10 years ago (OMG have I really been playing with my beantin that long). Used a secondary screenwash pump and added a seperate tank with neat water in it.
Only thing I found with it was once I'd stopped and the excess water was dribbling on to the space people would tell me my car was leaking.
Did it make a difference? I'm not sure either way but it seemed a lot of hassle and more plumbing and wiring for an effect that if at all present was minimal.
PaulT
Didn't check that and have not tried it yet could be plan B
The pump has to be lower than the nozzles or it will dribble
PaulT
Balls Deep!
IMO and from what I have read, anything under about 150psi of pressure creating a extremely fine mist of water is next to pointless!
The key point is that the water must evaporate – it is this change of state from water to a gas which absorbs the energy/heat. If the water droplets do not evaporate, they basically provide almost no cooling performance. And the key to getting water to evaporate is to use very small drops – an atomised mist – which dramatically increases the surface-area-to-volume-ratio of each drop, promoting evaporation.
But as you say it's just for fun and keeps you from drinking beer! lol
One thing I would do differently is use a Charge temp switch not a boost preesure switch, that way you attempt to maintain a constant control over the charge temps rather than only cooling when on boost.
Balls Deep!
Nope!
Some of my Info comes from this site look for yourself.... http://autospeed.com/cms/title_World...0/article.html
Although you would get better results power wise using water/meth injection!
focus rs 1672
I only done this after seeing the water spray on my friends Subaru STI, I always thought it would have been a super high pressure mist that covered the whole intercooler but it wasn't. I didn't think it would make any difference or everyone would have it by now but it can't be that bad an idea or Subaru wouldn't bother.
Mark RS
12-10-2015 06:01 AM
rsguy
44
29-09-2015 03:29 PM
boost, box, car, drop, effect, ice, intecooler, intercooler, kit, sprai, spray, spraying, temp, water, waterintercooler18t
