help, car wont start on key now and again!!!
Old 19-12-2006 | 08:02 PM
davsmith64's Avatar
davsmith64
Default help, car wont start on key now and again!!!
help my car only starts by the key every now and again,, i can go to the car and it will start fine with the key, then if i turn it off and try again after a journey, it wont start with the key! i need to start it with a button start.. its very random!!! cheers dave
Old 19-12-2006 | 08:17 PM
Ad4m RST's Avatar
Ad4m RST
Starter motor goosed....
Old 19-12-2006 | 08:28 PM
davsmith64's Avatar
davsmith64
cant be as it starts with the button start..
Old 19-12-2006 | 08:47 PM
SafeChav's Avatar
SafeChav
Scrap it
Old 20-12-2006 | 03:44 PM
gaz s1's Avatar
gaz s1
Originally Posted by SafeChav
Scrap it
class
Old 20-12-2006 | 03:45 PM
davsmith64's Avatar
davsmith64
yet another post been turned into a piss take!!!!!
Old 20-12-2006 | 04:15 PM
Moonie's Avatar
Moonie
Check the connections on the ignition switch, could have a poor connection or faulty switch causing excess voltage drop. Also worth looking where the button start is wired into, make sure the connections/joints are ok.
Old 20-12-2006 | 05:08 PM
Badman38's Avatar
Badman38
on your starter motor you have two wires one main power feed and the other one which will be the problem is connected to the starter motor solenoid. first time you start the car or if its left for a while it will start but if you stop then try to start it straight away it wont start. i bet the stud the wire connected onto is loose the heat from the exhaust down pipe always causes this to happen. only remedy for this is to somehow weld the stud or buy a new starter motor and heat wrap the down pipe.
Old 20-12-2006 | 07:26 PM
SafeChav's Avatar
SafeChav
mate.........calm down it was a joke.
And as for the comment............was i or was i not trying to help you on this thread which you just stopped replying to.........
https://passionford.com/forum/viewto...light=#3450940
Old 20-12-2006 | 08:15 PM
davsmith64's Avatar
davsmith64
yeah sorry mate
Old 20-12-2006 | 08:24 PM
SafeChav's Avatar
SafeChav
So anyway.................back to the question in hand. Thsi switch and relay assembly. Where do the wires from the relay contacts join to on the cars wiring
Old 26-01-2007 | 03:26 PM
davsmith64's Avatar
davsmith64
ok yeah the cranking live goes to the wires on the ignition switch, so obviously this shows that the problem is further up the wires i.e. the switch?
Old 30-01-2007 | 09:34 AM
orion_rst's Avatar
orion_rst
Time to play The Game HHH
I have the same problem at the moment. After a good run 'sometimes' the car doesn't start. I just had the self-starter serviced after re-building the engine, so I was going to give a try by disconnecting the cold start valve. i'm suspecting it might be causing a fault... we'll see
JoeyBoyden
04-01-2024 02:36 PM
Adam-M
22
10-08-2015 10:46 AM
yawiejon
15
09-08-2015 06:36 PM
tankybaby66
09-08-2015 07:13 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: help, car wont start on key now and again!!!
