crunchy reverse s2
I think all ERST's have a slight crunch going into reverse as there is no synchro ?, people suggest popping it into 2nd before going for reverse I think.
The problem with crucnhy reverses is common to most cars. They crunch because unlike the forward gears, there is no synchro-mesh, its a straight gear on gear mesh.
TRY: pushing the clutch in and waiting for 2-3 seconds then selecting reverse, i bet you theres no crunch (the theory behind it being it gives the gears time to stop spinning)
AND IF IT does: you are either a lazy muppet and are not pushing the clutch in properly
, or the clutch isn't disengaging properly (could be a few reasons why)
my s2 used to do it b4 i took it off the road whether u selected reverse or quickly. my old xr2i also used to do it. i found puttin the car into first then goin into reverse stopped it from crunching
Originally Posted by TURBO BOI
the clutch cable adjustable? on s2?
Try what i suggested further up first, you would be surprised......
As i said its to do with the gears in the box spinning, you will find when the engine is cold it does it less, because the gearbox oil is still thick and cold.
Trust me, hold the clutch in for 2-3 seconds everytime before selecting reverse and you should never hear a crunch again
The Enigma
12-09-2015 10:12 PM
