Braking Problem
Old Apr 20, 2006 | 01:15 PM
Default Braking Problem
when i want to slow down mainly at high speed the steering wheel moves left and right in my hands quite harsh and takes awhile to actually stop. where as before my brakes were shit hot for a escort lol.
i have cossie rear brakes on this, not drums, if thats any help.
i looked at the disc and pads and they seem ok and the fluid level is fine.
any idea's or things to check?
cheeRS
Rob
Old Apr 20, 2006 | 02:26 PM
antony215's Avatar
antony215
Escort Rs Turbo
Might be warped disc's or balljoint gone mine did the same thing got new disc's and it's been fine since
Old Apr 20, 2006 | 02:39 PM
Drjones's Avatar
Drjones
Would have said warrped discs too!!!!
Old Apr 20, 2006 | 02:52 PM
Little_Hoss's Avatar
Little_Hoss
some people say when you put rear discs on that you need to have a larger master cylinder to cope with them
maybe some people mite be able to shed some light on that?
have they just started doin this or was it when you put the rear discs on?
Old Apr 20, 2006 | 03:35 PM
just started now its had the conversion now for about 3/4yrs. other than recently it was the mutts nuts for stopping.
Old Apr 20, 2006 | 04:18 PM
s2rstony's Avatar
s2rstony
just an idea but mayb u shld check the tracking. ive had problems wiv that in the past
Old Apr 20, 2006 | 04:21 PM
Drjones's Avatar
Drjones
does your wheel move while your driving (not braking)
Old Apr 20, 2006 | 04:27 PM
yes it does feel like it move not all the time.... feels like it pings sometimes when turning if that makes any sense?
Old Apr 20, 2006 | 04:28 PM
scortgti's Avatar
scortgti
is it only under braking that it does it??
Old Apr 20, 2006 | 04:30 PM
the steering wobbling left to right harsh when braking.
when i turn the steering wheel even slightly (sometimes) it feels like it pings.
Old Apr 20, 2006 | 04:49 PM
Moonie's Avatar
Moonie
Sounds to me like a warped front disc/discs as you are only feeling it through the steering. As you mention there is also a clunk when turning i would get the balljoints, track rod ends etc etc checked for play as these could also lead to brake vibrations.
Vibrations caused by excessive run out in the rear brakes are usually felt through the seat/floor.
Old Apr 20, 2006 | 04:55 PM
thanks a lot peeps that's very helpful.
ah one thing also last year one of the rear calipers did seize up. could that be playing up again or fucked anything else up?
Old Apr 20, 2006 | 05:02 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Not really mate - warped discs. Chnage them, wheels balanced, problem most likely solved.
Old Apr 20, 2006 | 05:14 PM
thank you ill try the discs first
Old Apr 20, 2006 | 07:44 PM
notSteveS2's Avatar
notSteveS2
to be honest mate i found my steerin wheel juddered rapdily wen i had warped discs...
the other thing i wud look at is track rod ends and ball joints as sed but i changed me steerin rack too as it was also fooked...
defo check trackin too!!!
and wheel balancin!
Old Apr 21, 2006 | 12:00 AM
cheeRS everyone
Old Apr 21, 2006 | 10:20 AM
notSteveS2's Avatar
notSteveS2
Old Apr 21, 2006 | 11:53 AM
SafeChav's Avatar
SafeChav
I had a problem on my car which progressively got worse, vibrating when driving between 70-80, and really bad when braking, scary to an extent. I thought it was warped discs.
Put a different wheel on, problem solved
Try swapping wheels, failing that its probably going to be warped discs
Old Apr 21, 2006 | 12:06 PM
scottiemous's Avatar
scottiemous
More often than not warped discs, a Ford favorite
Check ball joints, tca bushes and rod ends for wear, as warped discs put
more pressure on them.
Also i found out on my first erst that the steering coloum bushes had worn
too, causing lots of vibrations also.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
