is there anyway to lock a cossie flywheel engine out of car
http://www.machinemart.co.uk/product.asp?p=040210258
will that help to totally lock it as the bolt is tight as fook
I have on old inlet valve with the stem bent at 90 degrees (you'll need to heat it to do this).
The stem sits in a block bolt hole, the edge of the valve head then engages with the ring gear.
Made this in about 1976 and have used it ever since.
problem is all my valves are in the head and i dont think removing the head gasket and taking a valve out to bend it is a good idea
spadge thats a good point but its the bottom pull bolt that is tight as fook
mains bearing again comes under rebuilding a engine to take the bottom pully off
snap-on dont even do what stu shown on display
HELLLLLLLLLLLP
not with the type that i am talking about it won't. basically, when you pull the trigger something inside spins up until it has a load of momentum. it is then released onto the output shaft with such a whack that it shocks the bolt undone. takes a few goes, but it works.
there are 2 types of wazz gun, maybe the one that you will try is the other type that will just try and turn the nut/bolt at the same time as shocking it. either way, with the inertia of the flywheel and the friction of the pistons and stuff, the crank will probably not turn.
if i lock the flywheel then i know its not gonna turn
btw how do i dont i aint gonna end up with a broken thumb like what happened to my missus last night
cant have 2 of us injured
I use what Nick is on about, can do it with the crank out of the car and don't have to hold it still, called an impact gun.
Also useful for tkaing final drives off diffs when holding them by hand!
PassionFords Creator
To be fair, although an impact ratchet "Can" work, he will still need a locking device or method to put it back on to 200NM if its done out of teh car.
dave the clutch as already been fitted, that was easy
its the bottom pully bolt thats being a cunt
gonna zap it and try a flywheel locking tool
if not is there anotherway to remove the cambelt and fit a new one
Originally Posted by Stu @ M Developments
To be fair, although an impact ratchet "Can" work, he will still need a locking device or method to put it back on to 200NM if its done out of the car.
Are you saying you wouldnt trust your customers to do that properly?
screw a bolt into one of the top bellhousing holes, pop a wooden wedge inbetween the flywheel and the bolt, and as you undo the bottom pulley bolt itll feed the wedge in the gap and lock it.
JoeyBoyden
Jan 4, 2024 02:36 PM
Red_bull
Aug 9, 2015 08:34 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
