Engine temps hot hot hot!!
Old Jun 29, 2019 | 02:36 PM
BlakeMoyle's Avatar
BlakeMoyle
Wish I had more time!
10 Year Member
Default Engine temps hot hot hot!!
Hi everyone, as title just been out in my s2 to have the mot and the engine temp is through the roof literally in the red any ideas? It’s chipped got 31 fitted panel filter and alloy rad and comtec 11” slimline blow fan and 82 thermostat, many thanks 🙏
Old Jun 29, 2019 | 04:27 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Should note car was running fine before I fitted rad and fan
Old Jun 29, 2019 | 05:35 PM
RichieST's Avatar
RichieST
Is the fan sealed tightly against the rad?
Old Jun 29, 2019 | 05:39 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Hi,
can you please describe what you mean? I’ve just fitted it with the fan fitting kit that you order with it?
Old Jun 29, 2019 | 08:31 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Sorry forgot to say it’s a half mount ic not a ful frontal so most of the rad is still exposed so I’m just confused what I’ve done wrong?!
Old Jun 30, 2019 | 09:16 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Any ideas anyone? Fan comes on when it should etc but the temp just keeps rising?
Old Jul 1, 2019 | 06:19 AM
OAP Pete's Avatar
OAP Pete
From EX Auto sparks, I take it this is a new Electric Fan fitted, are you certain it working the correct way round....ie... Air flowing from outside through the Rad to engine, your Fan motor for certain will be "Perminant magnetic" type, so reversing the 2 wires it will revers the Air Flow...just a thought . Pete.
Old Jul 1, 2019 | 11:50 AM
nigel b's Avatar
nigel b
is it in the red when driving or just at idle?
Old Jul 1, 2019 | 12:10 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Hi thanks for the replies, it is a new slim line fan and I have checked it’s blowing the right way, couple of my friends have said it could be a air lock? It seems to be when driving and standing still?
Old Jul 1, 2019 | 02:55 PM
martysmartie's Avatar
martysmartie
It's overheating, as the fan should never come on whilst in motion.
As to the cause, it's possible this could be an air lock.
Is the rad and bottom and top hose hot when this happens?
Martin
Old Jul 1, 2019 | 04:20 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Hi Martin,
to be be honest I don’t really know it all seemed very hot at the time, unfortunately I’m working away now all week and flying to Spain Saturday so I’ll have to investigate that further when i get back, what would that indicate if the top is warm but the bottom isn’t?
Thanks
Old Jul 4, 2019 | 12:48 PM
martysmartie
If they are not both hot it indicates a circulation issue.
Martin
5axo.rst
Aug 9, 2006 10:24 PM
PinkLady
Jun 19, 2005 11:15 PM
vroooom ptssssh
21
Nov 13, 2004 02:24 PM
fowls@blueyonder.co.uk
Jun 19, 2004 07:18 PM
Jun 18, 2004 11:09 AM
