Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Garage Heating options
Old Nov 22, 2018 | 12:34 PM
qed296's Avatar
qed296
Default Garage Heating options
So as the weather draws in the temp in the garage has dropped alot.
Got -1 the other night so I need to act.
I've seen some thermostatic wall heaters like the ones used in greenhouses but looking for recommendations.
or am I best to leave it to the elements??
Old Nov 22, 2018 | 12:59 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
The modern electric wall mounted radiators are thermostatically controlled, have frost protection and are very efficient.
Old Nov 22, 2018 | 08:10 PM
st220kyle's Avatar
st220kyle
Be worth insulating it well if your heating it, be a bit like pissing in the wind otherwise.
Although this can cause issues when parking a wet car inside.
Old Nov 23, 2018 | 08:39 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
I've got x3 prem i air 2 kw door curtain heaters in my garage , x2 heat setting , fan for summer , remote control , swing , digital program etc and Ł50 each .
I normally only have 2 on at anyone time and they heat the garage very well ,
as a sparky I would of purchased dimplex heaters but for Ł150 it was to much money
iVe had no problems with them and the only took 5 mins to hang
cheers paul
Old Nov 24, 2018 | 10:11 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i've got a large shed which is well insulated and damp proofed. i just use oil filled radiators for it as they retain the heat for a while and are reasonably cheap to buy! they also have their own thermostats so i set them to stay a little bit above freezing so as not to waste too much electricity when i'm not using the shed.
Old Nov 26, 2018 | 07:06 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
yes, my garage has massive insulation, even the garage door is over 1 inch thick as it is insulated and it has a building above to modern standard (celotex etc.) but if you park a wet car in there it stays wet until the morning. It also stays hot from the Engine heat....not ideal for a car to begin a humid environment.
Old Nov 30, 2018 | 10:07 PM
qed296's Avatar
qed296
Hummm...food for thought
As it stands it gets cold but I've got airflow passing through.
Not getting condensation and no damp hanging about is it gets wet.
I am now wondering if adding heat might create an issue??
Old Dec 8, 2018 | 10:36 PM
c20tbo's Avatar
c20tbo
Im putting a dimplex air curtain in mine, 6kw unit on a stat.
AustenW
47
Dec 17, 2009 02:34 PM
tony_turbo
18
Dec 29, 2007 08:38 PM
Adam_BlackRS
Motorcycle Chat & Sales
18
Sep 25, 2006 03:45 PM
Spax
Sep 27, 2005 07:37 PM
Rob Virgo
21
Aug 9, 2005 07:10 PM
