Temp guage / sensor problem
Old Aug 29, 2015 | 07:52 AM
Derek Burleigh's Avatar
Derek Burleigh
Thumbs down Temp guage / sensor problem
Just been doing a bit of work under the bonnet on my Escort Cosworth. Put everything back together, but as soon as I turn the ignition on the temperature gauge goes straight up to the red, with the car not even running!!
Is it possible I have dislodged something when putting it back together? I had most of the front right side of the engine bay in bits, possibly dislodged a sensor when putting the boost hose from intercooler to inlet manifold back on????
Where exactly is the temp sensor for the temp guage on the Escort???
Old Aug 29, 2015 | 08:53 AM
RichieST's Avatar
RichieST
Default Temp guage / sensor problem
Sounds like it's going straight to earth. May have pinched the wire or something?
Old Aug 29, 2015 | 09:13 AM
martysmartie's Avatar
martysmartie
What he ^^ said, check the wire hasn't got shorted. The sensor is on the right hand side at the front of the head.
Martin
Old Aug 29, 2015 | 02:23 PM
Derek Burleigh
Smile
Thanks guys, will go and have a look when it cools down a bit, still 31deg outside!
Old Aug 29, 2015 | 03:18 PM
RichieST's Avatar
RichieST
I'd take that over the miserable weather that we have here at the mo
Old Sep 4, 2015 | 07:35 AM
Derek Burleigh
Hmmm.... Not getting very far with this.
My temp sensor seems to have 2 wires coming out of it????
Is the a wiring diagram for the EEC IV Escort posted on here anywhere?
Old Sep 5, 2015 | 05:59 PM
martysmartie
Your looking at the CTS, this is not the sender, it just has a single wire and is on the right (drivers) side of the head.
Martin
Old Sep 6, 2015 | 04:46 PM
Derek Burleigh
Thumbs up
Thanks to those trying to help, but I'm still slightly confused!!
Let's not talk about "drivers side" or "passenger side" I have a LHD car!! It's also an EEC IV Escort, if that makes a difference!
The sensor I am looking at is on the inlet side of the head, just behind the cam belt (see picture below), is this the temp sensor that the temperature gauge uses??
Martin, isn't CTS "Coolant temp sensor"?
Sorry if I am being thick guys!! It's old age setting in!!!
Old Sep 6, 2015 | 06:53 PM
jsa's Avatar
jsa
The 2 wire sensor goes to the eec-iv. The one wire sensor goes to the gauge.
Have a look under the coil cover.
Old Sep 9, 2015 | 09:50 AM
Derek Burleigh
jsa is GOD!!!
OK, found temp sensor under the coil cover between the cams at front of head.
If I disconnect temp sensor then the gauge behaves, ie. doesn't shoot straight to the top when I turn on the ignition.
Question: Does this imply it is a temp sensor problem, rather than a wiring issue?
Question 2: Is it possible to change the temp sensor without removing the cam covers? If so, how?? It's a bit dark down there and I can't see exactly how it is fitted!!
Old Sep 9, 2015 | 07:46 PM
jsa's Avatar
jsa
Yes, it implies sensor problem. Slight possibility of a gauge problem. But not a wiring problem.
It is threaded, so unscrews like a bolt. Deep socket and extension required. From memory cam cover should be able to stay put.
Old Sep 10, 2015 | 07:01 AM
Derek Burleigh
Thanks John.
What are the chances of Ford (Mallorca) having a temp sensor for an Escort Cosworth, I would guess at 0%!! Looking like another call to Darren to post me some bits!!
Old Sep 10, 2015 | 08:55 AM
Marc sierra's Avatar
Marc sierra
A few weeks ago I replaced this sensor on my 4x4 sapph. But the sensor was located at the back of the head at the inlet side, very close to the oil dipstick. Is the sensor located differently on an Escort? I thought the sapph 4x4 and Escort engines were (mechanically) very much the same?
Old Sep 10, 2015 | 01:58 PM
Derek Burleigh
It's a 1996 EEC IV Escort Cosworth. different head to your car and the Webber Escorts.
Old Sep 16, 2015 | 06:27 PM
Derek Burleigh
€49 for a new temp sensor has fixed the problem!!
Thanks to all who helped!
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
Ben26
Sep 3, 2015 07:55 PM
