keys in mk1 focus ghia
can anyone tell me how i get back into my mk1 focus. i was sanding down the rear wheel arch when the doors locked themselves
. rather stupidly i left the keys in on the dashboard. i really need to get back into the car, as i have a baby who is due in under 2 weeks and have another mk1 focus to repair within the family. Please if anyone has a clue on how i can get back into the car without smashing a window it would be a great help, as have no breakdown and cant afford a locksmith and i really do want to avoid smashing any window as all my local breakers are closed for the Christmas new year period.
can anyone tell me how i get back into my mk1 focus. i was sanding down the rear wheel arch when the doors locked themselves . rather stupidly i left the keys in on the dashboard. i really need to get back into the car, as i have a baby who is due in under 2 weeks and have another mk1 focus to repair within the family. Please if anyone has a clue on how i can get back into the car without smashing a window it would be a great help, as have no breakdown and cant afford a locksmith and i really do want to avoid smashing any window as all my local breakers are closed for the Christmas new year period.
glenn that would of been a brilliant idea, but never thought of that. has anyone got any idea, as dont have a clue about going about powering up wires from 3rd brake light, nor do i have a spare power source
i never bothered with getting cover like that, as my focus is a work horse and just keeps going, shes only given me jip once before and thats after changing spark plugs and had to drive her to motor factors to get new hd lights when 2nd lead was partly seized to spark plug
The boot release button wont work if the car is locked.
I have heard that you can back feed the electrical circuits by energising the alternator with a jump wire, then coat hanger or something in and hit the window down button.
Or try getting some of the parcel banding tape stuff, feeding it through the door seal and hook it round the interior door handle.
well another car battery would do it, you would need to confirm which colour wire is the boot locking wire, you would need to expose some of said wire from its insulation . connect the - terminal of the battory to the car chassis , then the + vire a wire to the correct wire for the boot lock, this would energise the lock circuit allowing access to the boot of the car
As said, the favourite would have to be a bit of wire to press this switch, a soft bit of wood could be used to give a bit of leverage for additional clearance.
Martin
You need a wedge or use a door stop and hammer it in gently at the top corner of the door, you should be able to open it plenty enough to get a wire inside or a stick with a hook on the end to unlock the door
two people now have mentioned the easiest way to get into this car now and the op dismissed the 1st one so ill say it again take out the upper brake light and put 12 v to the wire for the boot release!! takes seconds and requires only a piece of wire and 12v!
finally got in the car last night. managed to hook the keys with a bit of wire and feed them back though the top of the door. now just got to finish sanding back the crappy paint from a previous owner filling in the scratch they tried to fill with paint and failed and failing miserably and repaint it all, not looking forward to repainting a entire panel
Adam Graham
Sep 6, 2015 06:04 AM
