Cleaning caked exhaust tip
Old Jan 19, 2014 | 11:45 AM
BM08's Avatar
BM08
Default Cleaning caked exhaust tip
Now im not talking a few months grime/shit, im talking about something that looks like its never been cleaned, its completely black, not even a tiny speck of silver can be seen
Ive tried what i normally do on my cars, a old cloth and AG metal polish but its not touching it, so would i need to use wet+dry paper on it? would that work?
I wouldnt let mine get this bad but i bought the car like it(rest of the car is very clean)
Old Jan 19, 2014 | 02:36 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Try some wire wool and metal polish
Old Jan 19, 2014 | 03:04 PM
paulsheerin's Avatar
paulsheerin
I'd give tar remover and something like jizer to break down the actual grime. agitate it with a toothbrush or something similar and let it soak for a while and keep repeating.
I've found with metal polish its great for bringing a shine up if the metal is relatively clean but doesnt do much if the piece is still covered in shite.
Old Jan 19, 2014 | 03:23 PM
locum8's Avatar
locum8
Try brasso. I've used it many a times on my exhaust and it works a treat. If it's really bad then let it soak for around 10mins then it should come off with a bit of elbow grease.
Old Jan 19, 2014 | 03:44 PM
adsrs1's Avatar
adsrs1
Use autosol and wire wool works a treat
Old Jan 19, 2014 | 04:55 PM
BM08's Avatar
BM08
Yeah don't think brasso etc is going to touch this
Wire wool it is then
Cheers chaps
Old Jan 20, 2014 | 07:06 AM
Retro Al's Avatar
Retro Al
RWD IS KING
Wire wool + metal polish
Old Jan 25, 2014 | 07:32 PM
Cossy Mike's Avatar
Cossy Mike
Soak it in WD40, then attack the pipe (NOT the mirror boxes) with a wire wheel on a grinder.
This will remove all of the shite and you'll be left with a dull stainless steel, then use a set of polishing mops, sisal wheel, mild then finishing mop and with the correct grade compound's
then it'll look like this after around 3 hours,
Old Jan 25, 2014 | 09:40 PM
zsdom's Avatar
zsdom
If its really bad soak it on Mr Muscle first for a while (but please dont get any on your plastics or paint work) the attack it with wire wool & metal polish
Old Apr 3, 2014 | 12:28 AM
HaggisTurbo's Avatar
HaggisTurbo
Wowsers that is immaculate under there!
I used to use tar remover and brasso when i did mine in the past
Old Apr 3, 2014 | 07:20 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Another vote for Mr Muscle spray oven cleaner. Will break down the heavy carbon deposits and then finish up with some metal polish (Peek/Autosol etc) with wire wool.
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Si B
Sep 12, 2015 06:49 AM
Adam Graham
Sep 6, 2015 06:04 AM
