Overfueling Help!
Old May 16, 2013 | 06:13 PM
stecozz's Avatar
stecozz
Default Overfueling Help!
Im running greys on a L8 ecu,ive replaced the water temp and air tem sensors,and it wont idle less than 1050rpm with the iscv connected even though its 900rpm when disconnected.
At idle the co is 7.5%! and it wont go any lower however much i adjust the co screw on the ecu.
Any ideas please??
Old May 18, 2013 | 10:21 AM
daz1968's Avatar
daz1968
Maybe map sensor as this also has a major effect on fuelling.
Old Jun 22, 2013 | 02:42 PM
Stu @ M Developments's Avatar
PassionFords Creator
Check TPS alignment.
Old Jun 22, 2013 | 04:30 PM
stecozz's Avatar
stecozz
Seem better now ive set the tps to 0.20v closed even though i was told it should be 0.35v.
The beauty of buying non standard cars that have been messed with eh!
Will have to get it up to you to check
Old Jun 22, 2013 | 04:34 PM
Throttle angle is absolutely critical to the ECU's idle, warm up and overun strategies. We set them in degrees via IAW monitor as opposed to V's as its far easier and more intuitive.
Old Jun 22, 2013 | 04:40 PM
stecozz's Avatar
stecozz
Wont tick over less than 1000rpm either even though ive set the base idle, the mapper told me that it was set like that.
Does that sound right?
Old Jun 22, 2013 | 04:57 PM
Weber looks for 850 - 900 rpm and raises it if it sees it lower or requires it due to coolant temperature. If you set it to 900rpm when hot and then plug in the ISCV and it changes, something isnt quite right.
Contrary to popular belief - The ISCV is NOT there to control idle speed.
Old Jun 24, 2013 | 08:12 AM
delbee1's Avatar
delbee1
Hi Stu
What should the TPS be set to in degrees??
Old Jun 24, 2013 | 08:47 AM
Zero - closed.
radiant red
43
Oct 26, 2006 07:36 PM
robbyridz
Oct 20, 2006 04:43 PM
bunjeeman
Sep 10, 2006 10:39 AM
timrud
Jun 20, 2006 09:05 PM
xr4x4rs
Sep 5, 2005 12:44 AM
