online diognosis please LOL.......OVERFUELING (part two)
Old 22-10-2006, 08:09 PM
radiant red
radiant red's Avatar
Default online diognosis please LOL.......OVERFUELING (part two)
just rebuilt my cosworth as mentioned in a previous thread
but its overfueling like its on antilag!
running so rich its coughing out black smoke at idle goes off the scale on gas analyser!ive checked cam and ignition timing,checked sensor wiring i even checked to make sure the fuel return isnt blocked so no increase in fuel pressure.
i have increased rpm to 2500 dont wanna go anymore as its a new engine and it sounds like a rally car missing and coughing
could a fooked map sensor cause this?thing is it was ok before i rebuilt it gonna dig deeper tom but i just wondered if anyone has come accross this scale of overfuling only way i can describe it is it sounds like a crackling rally car
any help would be great i know its impossible to say without looking but........
Old 22-10-2006, 08:22 PM
Toe Knee
Toe Knee's Avatar
Worth getting the fuel pressure checked, if its too high then it'll over fuel.................
Old 22-10-2006, 08:24 PM
radiant red
yeah i know mate but we dont have a pressure kit yet.....will borrow one tom but it was fine before
Old 22-10-2006, 08:28 PM
The Youth.
The Youth.'s Avatar
sounds like either a map sensor fault or the blue ect temp sensor
steve
Old 22-10-2006, 08:29 PM
Toe Knee
Toe Knee's Avatar
Has the tamper proof cover been taken off?! if it has the grub screw could have moved poss.
Has anything changed to the engine ie spec/chip injectors?!
radiant red
Steve
as in the water temp or air?gonna get both tom if they dont fix it ill send em back
Old 22-10-2006, 08:31 PM
radiant red
nothing changed at all in regards to the setup mate,the pressure regscrew? it has no cover just a slice of silicon mate
Old 22-10-2006, 08:34 PM
dave cos4x4
dave cos4x4's Avatar
map sensor imo.
Old 22-10-2006, 08:35 PM
Toe Knee
Toe Knee's Avatar
Blue is water mate the air should be brown.............
Worth trying another reg or checking it on there as it means the screw under the silicon has been adjusted at some point if its got silicon on it. I took mine 2 stu ages ago and had the same thing silicon in it, turned out it was fooked and leaking air which also cause oil like deposits in the throttle body/inlet manifold!!!
RS500/364
RS500/364's Avatar
Map sensor to me !!
Old 22-10-2006, 08:37 PM
CosKev3
CosKev3's Avatar
Thats what MSD do to the top of fuel reg after setting fuel pressure
As above,sounds like either ECU water temp sender,blue one by dipstick on back of head,or MAP sensor
Old 22-10-2006, 08:44 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Not more problems for you
You seem to be having as much luck as me
Steve.
Old 22-10-2006, 08:59 PM
radiant red
but its overfueling real bad,if for example water temp sensor was disconnected when running ok it would not overfuel like this....possible map its a 3 bar and its been looking after 34 psi for a while now...
Old 22-10-2006, 09:00 PM
radiant red
Steve.
luck........haha ha whats that then
Old 22-10-2006, 09:03 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I would not drive it if its overfueling that much.
Steve.
Old 22-10-2006, 09:04 PM
radiant red
oh and its idleing a little higher prob due to excess fuel.....
Old 22-10-2006, 09:11 PM
PeterLucas
PeterLucas's Avatar
Have you checked piping to map sensor, if its split or leaking then the map sensor would see less negative pressure and fuel pressure would be higher.
Check with someone whios sober tho mate!
Old 22-10-2006, 09:22 PM
radiant red
that will be me then not had a beer all weekend due to frigin car
car is at work but pipe is fine mate,but............
just remembered something
i steam cleaned inner wings whilst engine was out and map sensor got a good soaking,hope i broke it at least i will know what it is
Old 22-10-2006, 09:27 PM
PGT
PGT's Avatar
Worth trying another reg ................. I took mine 2 Stu ages ago and had the same thing silicon in it, turned out it was fooked and leaking air which also cause oil like deposits in the throttle body/inlet manifold!!!
exactly the same for me - massively overfuelling. fuel pressure reg was working but leaked fuel down the vacuum pipe into the manifold which somehow turned into "oil" which settled in the manifold also diagnosed by stu, he recognised symtoms straight away
Old 22-10-2006, 09:40 PM
radiant red
exactly the same for me - massively overfuelling. fuel pressure reg was working but leaked fuel down the vacuum pipe into the manifold which somehow turned into "oil" which settled in the manifold also diagnosed by Stu, he recognised symtoms straight away
i have had the pipe off the reg no fuel leaking but i do need to test fuel pressure
Old 23-10-2006, 08:45 AM
PGT
PGT's Avatar
i dont think you will see anything simply by takjing the pipe off. have a look in the manifold (if indeed this is the cause).
Old 23-10-2006, 09:57 AM
Dicko&Vacant
Dicko&Vacant's Avatar
when my map sensor burnt out due to getting wet it was doing exactly the same thing mate. you couldnt even rev the car up it was just pouring black smoke out on tickover
hope you get it sorted
Old 23-10-2006, 11:12 AM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Map sensor is likely, as is C AND ATS.
However, make sure you havent got the phase and knock sensor plugs wrong or the injector and ISCV plugs.
Old 23-10-2006, 06:32 PM
radiant red
sorted fuelling issue it turned out to be a block vacuum take off for the map sensor so once the plugs cleared she sounded sweet as a nut
but just as i were about to go home the dam thing cut out on me
i thought it ran out of fuel as it was very low so i put a gallon in and it still wont start.............and then it did on and off,when it cuts out the there is still a spark its as tho its cutting the fuel somewhere proper getting pissed off now
Old 23-10-2006, 06:43 PM
radiant red
oh and when the thing tries cutting out the air injector valve goes scatty
Old 23-10-2006, 06:48 PM
Tarren
Tarren's Avatar
Feel for you mate
you have had some real bad luck with that car
Old 23-10-2006, 06:51 PM
Administrator
That sounds like a BAD CONNECTION IN TEH ECU.
Have you had the ecu apart? Honestly? If so, i can tell you what to try, if not, erm, well i wont. lol
Old 23-10-2006, 06:52 PM
radiant red
not even clocked 500 mile up yet mate
im at a point nearly now where i feel like taking it to local tuner and saying fix, this back in a week
someone suggested driving it into a river i would but it would cut out before i got there lol
Old 23-10-2006, 06:55 PM
radiant red
Originally Posted by Stu @ M Developments
That sounds like a BAD CONNECTION IN the ECU.
no please do
had the ecu out as we had the pectel monitoring system diognostic thingy plugged in to look at live data of sensors,only reason i took ecu out was to fit another as you locked me out of mine
ive un and replugged ecu but not had it open,what can i try??
Old 23-10-2006, 06:56 PM
jon@work
jon@work's Avatar
If it has been overfuelling that much, check your oil - on a mate's car, the water temp sensor wiring was screwed and the amount of fuel that got into the oil after running for 10 minutes was very surprising. I'd suggest you drain the oil and either refill with the drained oil if it looks OK or replace it.
Old 23-10-2006, 06:58 PM
radiant red
i did this as soon as i had the thing running well mate
Old 23-10-2006, 07:00 PM
Administrator
Nothing then, my original thought wont be valid i expect.
Old 23-10-2006, 07:18 PM
radiant red
bugger thought it was sorted then lol
gonna hard wire fuel pump in morn to eliminate that i know theres a spark,may also go through that entire section of loom and check evertything
Old 23-10-2006, 08:02 PM
DazC
DazC's Avatar
Last time I had that fault it was a MAP sensor issue reading boost when it was only cranking over.
Old 23-10-2006, 08:08 PM
radiant red
gotta be linked to map sensor surely,this is where the ecu gets its info to tell the air injector to work right?
Old 24-10-2006, 01:02 PM
Butch.
Butch.'s Avatar
the tps ans map sensor are the main things that will trigger the air injector i had to put a new plug on the tps because the air injector was going mad on tickover so try that or the map sensor mate
Old 25-10-2006, 03:27 PM
radiant red
all sorted mate cheers covered 100 miles trouble free
thanks for help everyone
Old 25-10-2006, 04:05 PM
Administrator
What was it mate?
Old 25-10-2006, 05:15 PM
Butch.
Butch.'s Avatar
yeah what was it?
i think u need to get stu to change ur user name from radiant red to magenta red
Old 25-10-2006, 06:44 PM
radiant red
What was it mate?
Borrowed a mates 3 bar.....runs sweet
Left mine on heater just in case it has moisture in it,but if not ill buy a new one
Quick Reply: online diognosis please LOL.......OVERFUELING (part two)
